how much power do i stand to lose??
so long story short my ls6 is quite possibly cracked somewhere and and is causing a massive vacuum leak, so i am switching back to my ls1 intake the car has the current mods tsp v3 cam, tsp prc 2.5 ls6 heads, bosch ev1 #42lb injectors, ls6 ported oil pump, tci 3000 stall, trunion upgraded roller rockers, as of right now the car IS NOT tuned, my tuner couldnt tune it with the vacuum leak so im curious what you guys think i will make power wise with all my mods with the ls1 vs the ls6?
so your ls6 intake has a leak and you are switching back to your ls1 intake? if that's it id say 30-40 less with out a tune just a guess tho with a tune probably 10-20 less again just a guess.
it may just keep in mind that with a stall the dyno will read a low number compared to the same exact set up manual will. id say your def over 400hp at the crank for sure but dont be too discourage if it reads a little below it. If i was you id get the LS1 intake ported then put it on and your car will run like crap if its not tuned. So go get a tune after you ported your LS1 intake and then dyno it. What was you making before with the LS6 intake? Well I see that you have heads and a cam so you should be over 400rwhp but like you said you had to go back to a LS1 intake so it may read close to that.
Ahh I see, well just port the LS1 intake and I do believe you might make 400rwhp. you could also just sell it and your throttle body to help buy a 92 Fast intake and throttle body and that will definitely get you to your goal of 400rwhp with a good tuner. you can buy them used on e-bay or here on this site or you could buy another ls6 intake on e-bay and this site. Good luck with your goal and hope you reach it.
