Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
unleaded race fuel in Lancaster PA?
Old 01-13-2013, 10:29 AM
outkast6991's Avatar
Default unleaded race fuel in Lancaster PA?
anybody know where to get some around Lancaster? I'm trying to diagnose a kr issue and would like to add some to see if it is actual kr or false. also any suggestions for the mix amount would be great. thanks
Old 01-14-2013, 08:07 AM
dschmittie1's Avatar
Sunoco on 462 in Wirghtsville has unleaded 100 Right
Old 01-14-2013, 09:52 AM
C5kid's Avatar
^^ that is what I was goin to say. It's salty, but that is how I diagnosed my KR issue.
Old 01-14-2013, 10:40 AM
I'm ok paying just not sure how much to mix to rule out actual knock
Old 01-14-2013, 01:01 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Well, when it comes to mixing actual gasoline mixtures, it's pretty simple. If you have half a tank left, and it's "93", then mixing in another half tank of 100 would bring the octane rating up to roughly 96.5 or (93+100)/2. That's plenty high to see if it's real knock or not.
I had a similar issue this fall. I had filled up in Jersey and the guy put in 87 by accident, but I didn't realize it till later when I had gotten on it in a later drive. I had crazy knock all the time, but put in about 5 gallons of 100 and it instantly went away, or within about 2-3 miles of driving.
I logged before and after the fillup and it was instant how quickly the knock went away.
Old 01-14-2013, 06:18 PM
Thanks for the info. I'm getting a couple degrees of kr from 3600-4800 or so. Timing was at 24 with 2*kr so I pulled 2 from the area and tried again. Same result. Pulled 2 more and still the same. I'm now at 18 through that area and still seeing a degree or so. Tried richening up the area with no change either. I'm really starting to think its noise from the solid mm's
Quick Reply: unleaded race fuel in Lancaster PA?
