Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Spring maintanence reminder
Old 04-11-2007, 03:53 PM
LS1Tech Sponsor
Slowhawk's Avatar
Default Spring maintanence reminder
Since everybody is getting there cars out I figure'd this shoiuld be posted.Here is a list of the most common problems I see due to the lack of maintanence and ussually affects the way the car runs.
1- Clean the Mass air meter.Take it apart and clean the metal element with Mass air cleaner or carefully with a towel(watch out for the resistors).
2- Air filters -if ussing a K+N put very little oil (or none).Too much will go onto the MA and cause the car to run lean at WOT.
3- Fuel filter -Replace it if it has over 25k on it or for a piece of mind.A clogged filter can cause fuel pressure to drop under load.
4- Clean grounds -This is becoming a very populer problem since the cars are getting old.The connections get weak and cause alot of problems.It is also the main reason if your 02's are lazy on switching. Take off the driver side and pass side,sand down the contact point and reinstall.
That should do it
Old 04-11-2007, 06:01 PM
Moderator
davered00ss's Avatar
Thanks for the reminder Don.
Old 04-11-2007, 06:08 PM
02SCVette's Avatar
#4 worked wonders for my car, right Don.
Old 04-11-2007, 06:45 PM
peterock98's Avatar
Thanks for the heads up.
Old 04-11-2007, 07:13 PM
cknhwk's Avatar
Talking Thanxsss For Looknnn Out......
HEY HEY HEY ....
I CAN DIG IT WARRRRIOR....
Old 04-11-2007, 07:38 PM
CT Hotness
lilstephsls1's Avatar
I actually did most of that . Cleaning the MAF and throttle body made a HUGE difference too! The car feels like it gained more HP, hehe
Old 04-11-2007, 07:48 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Which grounds are you talking about? The one on the rear of the driver's side head or the two on the front of each wheel well?
Internet Mechanic
BlackScreaminMachine's Avatar
All I got left is the MAF lol. My TB is bone dry. woot!
Old 04-11-2007, 07:51 PM
01pewterbird's Avatar
I'd also like to know this.
Old 04-11-2007, 08:35 PM
lomaximumta's Avatar
Thanks for the advice. I am ready for Spring
Old 04-11-2007, 09:07 PM
LS1Tech Sponsor
Slowhawk's Avatar
Wheel wells,headlight area too.
Old 04-11-2007, 09:32 PM
ynkssws6's Avatar
Can I get a part # on the fuel filter, been meaning to do this one. Thanks!
Old 04-11-2007, 09:39 PM
lastcall190's Avatar
IIRC the GM part number is 25121942, or at the store AC #GF627. Can anyone confirm?
Thanks for the reminder Slow, I gotta change mine and do the contacts.
-J
Old 04-11-2007, 09:44 PM
DanaliHD's Avatar
this might be a stupid question, but, since i'm running SD does it matter if my maf is dirty? cause it is.
Old 04-11-2007, 10:57 PM
LS1Tech Sponsor
Slowhawk's Avatar
No,because the MAF wires are cut anyways.
Old 04-12-2007, 12:11 AM
98camaroLS1M6's Avatar
good reminder!
Old 04-12-2007, 06:46 AM
DannoWS6's Avatar
Good advice.
I clean my MAF twice a year with electronics cleaner from Radioshack.
I need to check my grounds, my driver side O2 always throws insuffient switching every month or so. Replacing it only seems to help for and extra month. I think it just heats up to slow.
Old 04-12-2007, 06:52 AM
Internet Mechanic
Originally Posted by DannoWS6
Good advice.
I bought vette o2's and never had a light or code since the header install, I was told they heat up quicker. COuld be an idea.
Old 04-12-2007, 07:16 AM
nodnarb481's Avatar
by MA did you mean MAF? if not whats the MA?
Old 04-12-2007, 07:23 AM
DannoWS6's Avatar
Do you know the part #'s off the top of your head?
short for Mass Air.
