Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
30x10.5x15 Hoosier Radial Slicks...
Old 04-16-2007, 02:00 PM
TTPMatt's Avatar
Default 30x10.5x15 Hoosier Radial Slicks...
They fit! We also cut a bunch of weight out of the car to make them fit, a whopping 3.8 lbs of metal combined with rubber. Here's a sneak peak:
Old 04-16-2007, 03:41 PM
CARTEK Racing
WS6TransAm01's Avatar
what gear are you going with for that much tire?
Old 04-16-2007, 04:06 PM
LS1LT1's Avatar
Cool
If I had bought that car that was one of the things I was considering, a tall tire to make it's non lock up/non overdriven 3 speed and 4.10 geared rear more 'street friendly', I don't do the trailered car thing.
Old 04-16-2007, 05:07 PM
TTPMatt's Avatar
Alex: Im going to run the 4.11's still and run the brake up higher see if I can hook on these guys. I cant go above 4000 on the tbrake or it breaks loose. The new tires are more for the future plans of the car.
We'll see what happens at etown weds.
- Matt
Old 04-16-2007, 05:49 PM
Race your car!
JL ws-6's Avatar
with that tire on it you can spray that thing pretty good and not run out of gear
Old 04-16-2007, 06:39 PM
TTPMatt's Avatar
I wont need spray with the new motor. However, we are so booked that I won't be able to touch my car other than little b/s stuff until the fall at least.
Old 04-16-2007, 07:17 PM
Moderator
thechef's Avatar
do the work on sat or sundays since the shop is closed
Old 04-16-2007, 08:17 PM
iamsickofitall's Avatar
yeah, that's what your new hours are for
Old 04-17-2007, 07:14 AM
nhra_crazy's Avatar
Good to see they fit Matt!!! I was going to ask you if those tires were for your car when we were there on Sat..
Old 04-17-2007, 10:00 AM
Hawkn01's Avatar
Thats the tire I ran with my combo, your gonna like them Matt. Don't be shy with the air pressure, they like it, remember there a radial not a bias tire. I think you'll find they sixty better, they mph better, and they are much more stable on the top end than a bias tire.
They sell two versions of the tire, the 30/10.5R-15 lightweight radial(C06) compound that weighs 23lbs. And the 30/10.5-15 radial (C07)compound that weighs 26lbs.
The lightweight is a good tire for cool spring and fall racing with the softer compound. The (C07) radial is a good summer heat tire.
Good luck with them, you won't go back to a bias tire after running these.
TJ
Old 04-18-2007, 10:07 AM
TTPMatt's Avatar
Ya TIm I thought of your car when I ordered these actually, lol. I went witht he C07 since we are coming into the summer
I am hoping to get out tonight to etown.
- Matt
Quick Reply: 30x10.5x15 Hoosier Radial Slicks...
