Wheel hop like a mofo.
Wheel hop like a ****.
Maybe it will be corrected when I get around to installing the LCA relocation brackets. Maybe it didn't have enough air in the tires. Maybe I need to get an adjustable TA and change the pinion angle....etc.
For now, I want to install the LCA brackets and also install a big old sway bar. As it sits, the car must have the wimpiest stock sway bar available. It's tiny. So I wanna get a BMR drag bar or the solid mount one from Spohn. I figure these are best for street/strip. I think I prefer the BMR, I like the mounting tabs better on the BMR.
Eventually, I'll also get an adjustable tunnel mounted TA, probably a UMI.
Sound like a plan? Any local shops offering a deal on the BMR drag bar?
LS1TECH Sponsor
i have the sphon (drag bar)and it works great, easy to bolt on then drive to someone that can weld it for you brackets will help too. what tires were you running. cold nittos and roads will hop like the easter bunny this time of year regardless. also to much air usally ampliphies hop if it is present
been from very bad to pretty smooth now . even with the 9"
I guess everyone was at Church....
Eagle F1 clones with around 20 psi. I wasn't even trying to burn out, I just banged second and it shook like hell.
Hopefully the drag bar and the brackets solve it. I think I'll also stiffen up the rebound on the rear shocks and see if that helps.
