Preventing head lift!
I am going to be building my motor very soon for my turbo set up and was wondering which would be better to do. Either o-ring the motor or install the 1/2" ARP head studs! The motor will be a fully forged 347 with patriot stage 2's and I am by no means building a race car but would like to be able to run 20 psi w/out issues!
I would just run the heads intill they lifted and by then you would probley have enough money saved to get some good heads. The Dart heads have a pretty thick deck and you can get them brand new for under $1500. Theres probley beter heads out there but that price is hard to bet for a head with a thick deck. I ran 20 psi on my AllPro heads, 3/8" Arp studs and 6.0 MLS head gaskets and they NEVER lifted. There a great head but there alittle on the expensive side but worth it...
Justin
Nice. Have you talked to dave lately? I wonder if he got his allpro heads on yet. He said you and him turned the boost up to 12 pounds of so on his truck but it went lean. He said you had it tuned for 12 pounds but it was still was running lean. Did you get it figured out?
Justin
It doesnt really matter what heads you are going to run and if u O-Ring the heads and use 1/2" Studs...... if your going to push the motor beyound 20 psi u are going to start to push water (ie lift the heads) with any of them when its a 4 bolt setup. Its just something u are going to have to deal with and work on containing the coolant system.
Even some of the 6 Bolt Alum block guys push a lil water still.
Believe me ive been researching this like crazy, esp since im staying 4 bolt for a while....
Kyle
Kyle
Kyle
Kyle
Hey Kyle, On my last 2 passes before my rod let go I was at 23psi. and pushed no water. We turned the timing down to 15deg. in the higher rpms and that seemed to work very well.
Ask Fireball or mark how much water there pushing.... its some... its controlling it...
Let it push into the over flow.. drain it and add more to the coolant sysytem...
Yeah my last time out i was quite a bit more timing then that.. was at 26 psi and popped a head gasket....
Add 2* and I'd push a few ounces.
