anyone have a WPPP kit?
Old 10-27-2008, 08:41 AM
11 Second Truck Club
Superado's Avatar
Default anyone have a WPPP kit?
in case you're wondering...that's a water pump pulley pinning kit
to prevent the water pump pulley from being spun off the pump, dancing around under the hood like a pinball machine, then exiting out from under the truck and darting towards the wall...all of this resulting from the ProCharger taking a after 6+ years of service & performance while making the virgin pass down the 1320...on the new motor and tranny...
now the good news!
12.58 @ 98mph...
on a really fumblephruck of a run
Old 10-27-2008, 11:21 AM
Z06PSI's Avatar
Pics!!
Old 10-27-2008, 11:24 AM
Superado's Avatar
I'll try to get a couple posted...cablebandit has a video he's editing too...
Old 10-28-2008, 07:23 AM
Superado's Avatar
really nothing to take pics of other than a beat up water pump pulley...
everything else is fine...appearance wise...
I assume the bearings in the P1SC let go after 152k+ miles
Old 10-28-2008, 05:03 PM
Superado's Avatar
P1SC Head Unit is on it's way to ATI ProCharger...
Old 10-28-2008, 05:08 PM
Superado's Avatar
http://video.performancetrucks.net/v...4301223e4b.htm
Old 10-28-2008, 05:29 PM
Superado's Avatar
oh yeah...
I believe I forgot to mention that I hit the rev limiter on the 1-2 shift...
Old 11-05-2008, 04:50 PM
Superado's Avatar
ProCharger's customer service is top notch!
rebuild begins tomorrow...ships Friday...arrives next Tuesday!
upgrading to D1SC
Old 11-05-2008, 05:19 PM
Harley-Davidson88's Avatar
I assume they are rebuilding your P1SC unit and converting it to D1SC? How much does that set you back if you don't mind me asking?
Old 11-05-2008, 08:18 PM
Superado's Avatar
mine was considered a "major rebuild"...
not just a bearings and seals rebuild...
when it let go...it...let...go...
got the impeller as well...
Old 11-05-2008, 08:34 PM
Old 12-07-2008, 08:53 AM
Superado's Avatar
well...
maybe the ProCharger locking up was just a coincidence...
new D1 set-up ripped the pulley off the front of the new water pump yesterday!
on the first pass after belt wrap mod!
http://www.performancetrucks.net/for...lt+wrap+pulley
http://performancetrucks.net/forums/...+belt+slippage
found the pulley...heated it up with a kerosene and a propane heater...slid it back on and drove home...
I guess I'll get it tacked to the shaft tomorrow...
wondering now if I'm getting some twist under boost that may be mis-aligning the belt route that may be contributing to this???
Old 12-07-2008, 09:41 AM
EPP
EPP's Avatar
Hmm, I've never seen that happen before. It would be interesting to see what is happening while it is running on a loaded dyno. Safer yet, mount a camera in the engine bay area then make a wide open throttle run. As you mentioned, it may be bracket related. Bob
Old 12-07-2008, 09:55 AM
Superado's Avatar
maybe a rod w/ hiem joints from bracket to block somewhere would help...
Old 12-07-2008, 09:56 AM
HUNTER02SS's Avatar
I wonder whats up with this? 2 pulley's?
Old 12-07-2008, 10:03 AM
Superado's Avatar
chris-
i have NOOOOO idea...other than the suspicions mentioned above...
Old 12-07-2008, 10:16 AM
HUNTER02SS's Avatar
I have never wondered until now, but do they make a water pump for our motors or cars/trucks that would spin in "reverse"? Like the ford motors have a reverse style water pump and a standard rotation water pump?
Old 12-07-2008, 10:31 AM
cablebandit's Avatar
seems like that would only let us pick up the pulley off the right side of the track vs the left as we do now
Prolly flex......get it tacked and try again
Old 12-07-2008, 11:30 AM
HUNTER02SS's Avatar
I guess the truck blower set up uses the same belt for the blower as the accesories like the corvette, or is it dedicated?
Old 12-07-2008, 12:20 PM
same belt
Quick Reply: anyone have a WPPP kit?
