good streetable cam for supercharged 408
Old 11-11-2008, 08:44 PM
hedge's Avatar
Default good streetable cam for supercharged 408
alright im sure everyone will have different opinions but i got a 408 forged internals setting at 8.5 :1 compression and 317 heads ported out! got all the springs good to 660 lift hardened pushrods and etc.. need car to be easily tuned but like to get all i can .. wife wants to drive car so nothing pushin limits of user friendly.. epp makes a good cam its a 232 int 240 exh
.595 int .608 exh Lobe Sep 115.0 , Chuck Anders @ HPE likes the 235/242 on a 115 w/ .642/.612 lift on a street car because it starts pullin at 3k rpm!! help me help me!!
cant decide!!
Old 11-11-2008, 09:17 PM
cbr600rx7's Avatar
I have heard a lot of good things about the EPP cam as was considering it for my much milder stock cube set up. I would say you are in the right area and its probably going to come down to personal preference but some of the guys that run the car will chime in here in a few and give you some better feed back.
Old 11-11-2008, 09:19 PM
nvmy2000ss's Avatar
both would be a good cam. 640 plus on a daily driver though is alot of lift. I personally would go for the epp cam, in fact I did.
Old 11-11-2008, 10:43 PM
LS1Tech Sponsor
Slowhawk's Avatar
I'd say the EPP cam. 8.5-1 comp is alittle low for a supercharged setup so you need a cam to hold more pressure.
Old 11-11-2008, 10:48 PM
GT67METHV's Avatar
nothing like a 02 and up z06 stock cam...easily tuned
with great street manners. also, as a dd/wife vehical.
Old 11-11-2008, 10:51 PM
67Firebird455's Avatar
Epp =)
Old 11-11-2008, 11:06 PM
DeltaT's Avatar
What kind of supercharger? I'd cam different for a centri vs. a maggie or twinscrew.
Jim
Old 11-12-2008, 08:15 AM
Dumb Ass Vette Moderator
ls1290's Avatar
I have a 236/245//598/608//115 cam in my 402 and thing starts to really pull around 3500ish RPMs. But when it pulls, it pulls hard. Even being on a 115 LSA, there is a lot of lope.
First off, if your wife has no experience with a stroker SC car, she really should not be driving one. I don't mean to sound harsh, but it is way too easy for the car to get away from a you, but you sideways, and right into a telephone pole or another car.
Both of the cam you listed would make good racing cams. For a street car I would do some like 220/226//578/588//116 or 117. It will still make some good power, it would start to engage at a lower RPM, and the lope will much less.
Old 11-12-2008, 09:11 AM
hedge's Avatar
she is use to my hotrods she dont push it!! its a t trim supercharger, built to run 15 lbs. i probably can adjust headasket to change compression up a little. what compression would be best 9to1? i would like a little lope from the cam!!
Old 11-12-2008, 10:50 AM
BLOWNBLUEZ06's Avatar
I have A&A's cam. I love it! From memory, the specs are 220/234 117lsa. Very driveable. Perfect street manners and idle and plenty of power up top.
Old 11-12-2008, 03:13 PM
ss1
ss1's Avatar
ROT around here is 9.5 to 10:1 compression. What amount of dish do your pistons have? If you could ditch the 317 heads and go with a set of 243's, that may work in your favor.
Off topic, I'm putting together a 403ci LS2 to be run with a T-Trim and am thinking along the same lines as you regarding the camshaft. What type of car are you putting this in?
Old 11-12-2008, 04:39 PM
T/A KID's Avatar
IMO if you want a nice streetable blower cam I would keep the duration pretty low and actually tighten the LSA. I am actually not a fan of wide LSA's on a blower car, but LSA and duration is just a bi-product of the most important thing, overlap.
The T-trim is Vortech's 1200cfm blower and on a 400+CI LSx motor with good heads you'll most likely only see around 12lbs depending on the efficiency of the motor. I say with this centri blower setup I would cam the motor small (high 220's, low 230's on a 110-112LSA. With the 408ci motor you'll have a slight idle but nothing drastic at all, almost a sleeper effect. You'll have great low end TQ and once in boost it will pull like crazy. However if you want to soften the low end grunt you could always go a little bigger on the duration, but driveability will suffer. Let the blower/heads make the power, the biggest cam doesn't always make you faster
IF you really want this thing to be a screamer, raise the compression ratio a full point, install a FMIC, with a 100% meth kit.
What tranny you plan on running?
Old 11-12-2008, 04:51 PM
Moz
Moz's Avatar
If you are looking for a good blower(Centri) cam,The EPP cam is great.I have no surging,makes great power,and the Idle is exactly what I was looking for!
Old 11-13-2008, 12:03 AM
DeltaT's Avatar
I have the T-trim on my 383 with a solid roller, 230/236 on 112LSA, net lift .574/.585. That's like running about a 224/230 hydraulic roller, so I'm in with T/A KID on this one. With the bit extra cubes I might go to a hyd 228/234 on a 113.
How high would you like to spin this on a regular basis?
Jim
PS Btw the max boost I've seen is right around blower redline, 12.87 after the big FMIC and throttle. I bet the 408 with the right cam will max out between 11 and 12.5#.
My Site: http://home.mindspring.com/~jim_fisk/id1.html
Old 11-13-2008, 11:54 AM
mikes99corvette's Avatar
I went with ECS big Blower cam ! !
Old 11-13-2008, 01:29 PM
STAR's Avatar
Any idea on the specs? Do you have an idle video?
Thanks
Old 11-13-2008, 03:45 PM
macleod's Avatar
228/236 .571/.578 113 lsa
Old 11-13-2008, 05:50 PM
Thanks
ECS will not disclose the SPEC's
Quick Reply: good streetable cam for supercharged 408
