Is it worth swapping to an LS6 intake?
Old 11-25-2008, 03:26 PM
LSex's Avatar
Default Is it worth swapping to an LS6 intake?
I have a 98 SS with a V9 G-Trim, headers, and exhaust, and the original LS1 intake. My question is would I benefit more then a NA LS1 from the swap or less? Seems to me like the increased flow ability combined with the SC would make a bigger gain then with a NA car but I've heard that since the supercharger is already moving as much air as it can that the gain would be negligible, which is true?
Old 11-25-2008, 03:32 PM
67Firebird455's Avatar
It may make a hair bit of difference, just imagine FI as blowing through a straw, you open it up a bit, there is actually more volume of air going into the engine for the amount of restriction "psi".
Old 11-25-2008, 04:52 PM
Mavmavv's Avatar
Any less restriction is better, but like Firebird says, its not gonna be huge.
Old 11-25-2008, 07:40 PM
EPP
EPP's Avatar
It will still be worth changing over to. Bob
Old 11-25-2008, 07:47 PM
Bob - What about stock fuel lines/rails? When would you recommend changing those out? Just curious, seeing a lot of intakes coming with aftermarket rails with -6an crossovers, just wanted to your opinion while we're talking intakes.
Old 11-26-2008, 07:27 AM
BLNLS1/RX7's Avatar
Yes,switch it out.
Old 11-26-2008, 07:40 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Originally Posted by BLNLS1/RX7
Yes,switch it out.
The stock fail rails are perfectly fine for 475 and even up to 600. No point in swapping those other than the Bling-Bling factor.
The LS6 intake will net maybe about 10 ponies from what you are currently make. With a H/C packs over your stock one, it will perform better.
Quick Reply: Is it worth swapping to an LS6 intake?
