Need quick help mounting meth nozzle
Is it ok to mount the nozzle here? I am trying to get this thing ready for the track tonight. I don't have an aluminum bung I can have welded to the cold piping, and it is to thin to just tap.
I have this solenoid to prevent siphoning.
http://www.lethaldiesel.com/snow-per...e-p-21514.html
i would def try to mount it upstream of the IAT sensor, plus is seems like you would get even less optimal than normal distribution mounting it that close to the intake ports.
i have the alkycontrol kit and there is a nut that goes on the otherside of the nozzle that you put on the inside of the pipe, you maybe could find a nut and try that
good luck
good luck
yea before the IAT if you are using the meth to cool your intake temps, other side of the IAT if you are using it strictly for the octane values. I'd just go down stream for the best of both worlds but some times packaging doesn't allow it.
