Stock Bottom & Boost - Reliability List
Old 08-19-2014, 06:22 AM
  #301
ToxicWS6's Avatar
03 lm7 stock short block, epp blower cam, 243 heads, arp head studs, ls9 head gaskets, MP t76 front mount. ??? rwhp (guessing around 700 ish), 4months on 12psi, 5 months on 16psi, ran its *** off untill i changed exhaust from full exhuast out the back into my borla cat back to a fender dump, not sure if boost spiked or just to much flow for stock fuel rails but detonated 3 and 4 cylinder as soon as it was about to hit 6200rpms, i feel safe in saying if i had proper fuel system it would still be driving to this day
Old 08-29-2014, 12:28 AM
  #302
jake74's Avatar
88 foxbody. 2003 4.8 t76 cxracing turbo,turbo smart hyper gate,holley co2 boost controller,comp 232-236 duration 595-601 lift,ls7 lifters,comp push rods,trunion upgrade,trick flow valve springs,meth injection,holley hp efi,ls9 head gaskets,ebay studs,magnafuel 750 pump,80lb deka injectors. Glide with ptc 9.5 billet converter,pro brake. 8.8 with 3.55 gears. Mickey 275-60 pro radials. Car weighs 3370 with me. Went 10.08 at 137mph not hooking at 18 psi boost and 18 degrees of timing shifting at 7100rpm. Never been on dyno but figure 650-700 wheel horse power.
Old 09-21-2014, 01:57 PM
  #303
eddierm250's Avatar
Turbo lq4 broke three pistons in 24 hours with bad timing and vacum ran incorrect i was only seeing 3 lbs boost felt like it was running great. Timing a boosted engine is super critical so i agree with make shure you know that timing is good. for me it was very deceiving.
Bone stock long block lq4
gt45 turbo
Microsquirt
Old 09-30-2014, 10:59 PM
  #304
Kmspeedie's Avatar
Originally Posted by mrstepheneades
Made 775/668 final numbers on this day. Dyno not enough load so this is on only 16 psi. Makes 21psi on street. Stock ls1 with Tick cam. Stock bolts and all.
S475 turbo.
i can see maybe makin that # but not lasting...hows it holding up man? cus i havva forged ls1 im gunna throw in and if your makin god dam 800 wheel it doesnt even make sense..how have you not leaked somethin somewhere or pushed a head or rod..id like to know how its holding up
Old 10-03-2014, 01:11 PM
  #305
RONSBLACK1998TA's Avatar
1998 TA stock heads and bottom. Comp cams 54-457-11. (Not a blower cam, but I wanted something mean sounding. Lol) D1SC, 8 psi, 460 h/p @4000 rpm (3600 tq conv wouldn't lock), 82,xxx when installed, 89, xxx now. Still going strong. Just need a new tq converter.
Old 10-05-2014, 07:49 PM
  #306
dean85gt's Avatar
2007LH6 5.3 LS7 cam, ebay head studs, pac1218 springs. S472 T6 1.1 ar all in an 85 foxbody.
672rwhp at 18psi
735 rwtq
best so far is 10.26 @141.
Driven about 4000km this summer It goes everywhere including the woodward dream cruise which was 4 hours one way. Runs on pump gas and I have meth injection
Old 01-28-2015, 03:57 PM
  #307
Bluecobra's Avatar
I had a Whipple side mount on my 2000 5.3 ECSB from 60k miles to 145k miles making between 6 and 13 psi - different pullies - and from 320rwhp to 440 rwhp. Then I switched over to a MP122 at 145k miles. 14psi from the Maggie makes 525rwhp on a very conservative tune. Engine has just over 150k now.
Motor has never broken *knocks on wood* but I did break an output shaft once.
I don't beat on mine too hard though....
Old 03-01-2015, 03:25 PM
  #308
X R8TED's Avatar
Im at 735/695 with a stock LS2, YSI, 12psi, blower cam, 100% meth injection
Old 07-09-2015, 01:53 AM
  #309
Mikko's Avatar
Last summer, stock LS3 w. Paxton Novi 2200 and 8psi of boost, E85 fuel. 730fwhp. Bit of boost control issues and boost raised to 10psi after that came head gasket failure, took engine apart and found also slight bent on 2 connection rods.
At then repaired fastly with stock parts pistons / rods and kept boost in 8psi with no problems.
Now running forged motor.
Old 07-19-2015, 10:01 AM
  #310
Ls1nutZ28's Avatar
SBE Ls1, 71,000 Miles, E-85, 9" rear and built 4l80E, put down 671 on 12 lbs and 18 degrees timing. Has went 6.54 at 106 in the 1/8th. Converter needs tightened up. So far only have 1000 miles on new setup and still going strong.
Old 07-28-2015, 11:40 PM
  #311
arock24's Avatar
Newly acquired:
'98 SS SLP
D1SC with twin intercoolers
10-11psi
571rwhp
Installed around 40k, currently at 42600
Supporting transmission and rear end mods but nothing else on the motor.
No track passes, but occasional spirited driving. Everything has held up great, as usual.
Old 08-06-2015, 09:53 AM
  #312
GoodSpeed150's Avatar
99 Trans Am
T7875 1.15AR
10psi
550rwhp/550rwtq
Been on for over 17k miles
A few track passes, lots of racing.
Still together. I plan on installing a meth injection kit soon and up the boost to 12psi. Bone stock LS1 outside of BTR valve springs and pushrods.
Old 09-09-2015, 02:40 PM
  #313
Budget LS Guy's Avatar
Sick goodspeed. I aspire to be like you
Old 09-14-2015, 02:05 AM
  #314
LANCE ATKINSON's Avatar
Default Stock Bottom & Boost - Reliability List
SBE L33 PRC heads 10:1 23psi
Dynojet 921hp 908tq through 6spd on a shotty tune and now retuned!!
Pt78/75 E85 , 9" M9 3.50 gear
Huron Speed V1 kit, LS2 vmax ported intake,
Bosch LPG 160s fed by 2 bosch 044s and 10an feed line returned through factory 6an feed line,
Now it has th400 with brake, PTC converter,
Car has made two dyno pulls and 15 passes on 1/8 mile track leaving on 10psi the 5.75 pass
Attached Thumbnails Stock Bottom & Boost - Reliability List-photo758.jpg   Stock Bottom & Boost - Reliability List-photo308.jpg
Old 01-17-2016, 08:29 PM
  #315
vinnysnova's Avatar
Stock 5.3, twin borgwerner 366, 16* timing, 22lbs boost, 801whp on dynojet, 9.62@144 w/1.8 60' in 3400lb car. Been going 2 years, beaten viscously daily, Rockey Mountain Race Week 1300 mile veteran, 40+ 1/4 mile passes. Still runs quiet, 35psi at hot 600rpm idle with the a/c on.
Old 01-24-2016, 01:20 PM
  #316
4Jenna's Avatar
9.18@149.9
LQ4 sbe 110k miles +
Twin 67s on 14psi
Old 02-23-2016, 03:40 PM
  #317
salemech's Avatar
hey guys
I'm planning on cxracing 76mm ball bearing single turbo on a stock bottom end ls1 346. how much boost can it take, car used for drifting.
Old 02-23-2016, 04:14 PM
  #318
SLOW SEDAN's Avatar
Clean setup! Good to see another car run great without getting greedy with the timing. I have a single 88 on 13-14 degrees and ~21-24lbs.
I ran a 9.6@145 but I'm about 600lbs heavier. Have no idea what horsepower it makes since it hasn't been on a dyno but your setup at least gives me a rough idea.
Stock LM7 5.3 block I've been beating on for about a year. First with a 76mm now with an 88 and it shows no signs of giving up, just keeps getting faster.
- On3 88mm
- 20+ PSI/Haven't dyno'd just street/track tuned
- ~150k miles
- 5k+
- Nothing broken except differentials!
Old 05-29-2016, 11:03 PM
  #319
NitroFumesAteMyBrain's Avatar
Might as well get on the list...
2002 ws6
SBE ls1
M6
Turbonetics "Benita" TC78
10#
E85
115k install
About 100 miles so far
Ill let you know hp in two days when we go to dyno. Just street tuned now and it feels like its going to peel your face off between shifts, lol.
-made 585hp/598tq @ 10# and 15*
Theres a hole in my bumper....
Old 06-28-2016, 10:38 AM
  #320
svslow's Avatar
Stock Gen 3 4.8, cleaned up with new rings and bearings. S475 and LS9 cam.
About 500 miles total after initially getting it running. 13psi/13* on E85. Something wasn't happy.
Quick Reply: Stock Bottom & Boost - Reliability List
