supercharger timing?
Old 02-02-2009, 05:05 PM
stingr's Avatar
Default supercharger timing?
What timing do you guys run with your blowers? I'm running 7psi boost and I have mine set at 17. i think that may be a bit to low. I'm thinking about bumping it to about 20 or so.
Old 02-02-2009, 05:07 PM
BLOWNBLUEZ06's Avatar
I'm running 18° on mine at 18psi boost with the addition of methanol. Without methanol, I might try to run 15°. You might get away with 20° with that low boost level. I wouldn't try it unless you can log for knock just to be safe.
Old 02-03-2009, 05:15 AM
EPP
EPP's Avatar
We generally end up with the timing above 5000 rpm at 18 degrees with 93 octane fuel. Bob
