Lower radiator hose
Old 02-12-2009, 01:03 PM
tsx153's Avatar
Default Lower radiator hose
So I have a griffin radiator mounted vertical and I bought the stock lower hose for 99 LS1 and it does not fit on the radiator side. Its to small Will fit on the inside of the radiator... What are you guys using or am I missing something here?
Old 02-12-2009, 02:35 PM
sevanseriesta's Avatar
Only way to go, get bungs welded... Much safer
Old 02-12-2009, 03:03 PM
tsx153's Avatar
what about on the water pump side? what did you do there?
Old 02-12-2009, 04:36 PM
Did the same thing...
Old 02-12-2009, 08:37 PM
tsx153's Avatar
looks nice!!! I think I am going to have to do that!
Old 02-12-2009, 09:53 PM
98turbls1's Avatar
did you do that and how much for all of that stuff. Looks very nice. Any pics with it installed with steel braid?
Old 02-13-2009, 06:36 PM
tsx153's Avatar
bump would also like to see it installed!
Old 02-13-2009, 06:45 PM
needaz28's Avatar
I bought a hose from checker for 15 bucks. 1 3/4-1 1/2.
edit: here's the part # 52418 checker. it's made by goodyear.
Old 08-24-2009, 04:16 PM
tsx153's Avatar
anyone know the part numbers for this?? Is that -16an fittings?? Wanting to do that to mine!
Old 08-24-2009, 05:24 PM
forcd ind's Avatar
not sure what your working on, but sounds like you have a 1 1/2" hose, and a 1 3/4" outlet on the radiator-you could have your rad changed to a 1 1/2",
i think if you had room, Jegs or Summit has an adapter nipple that might work,
or run through some diff hoses at the auto parts store-you can get the thermostat housings in 1 1/2 or 1 3/4 to help
Old 08-24-2009, 05:50 PM
tsx153's Avatar
I am doing front mount TC-78 and I liked the idea of running braided line b/c of the heat of the turbo. And plus it looks a lot nicer on a show car. I have that same radiator and wanted to do the exact same thing he did... Thanks for the ideas!
Quick Reply: Lower radiator hose
