STS oil pump harness.. who eliminated it?
well im about ready to start putting on the kit myself here it a couple of days so i was wondering who eliminated their STS oil pump harness i already wont be using the meth harness because i have a different meth kit and wont be using the PCV system and harness and i have heard you can hook up your pump to the fuel pump harness which i have a racetronixs pump and harness kit going on the car... anybody done this and how did you do it pics are welcome
thanks matt
thanks matt
If you have a high volume ported oil pump you want to run the pump on high due to increased oil volume to the turbo or you can use an oil resrictor before the turbo or even both.
I have been running mine with no resistor since I got the kit and has worked fine for me.
1 Post
thanks matt
thanks matt
BTW, I DID run an idiot light from the rear scavenge pump to the dash. I did this so that the light (which I placed above the radio) would illuminate when the pump was receiving voltage. Figured if the pump was getting voltage....it was probably running. Figured this would be cheap insurance unless you want to run power to the buzzer w/out using the STS harness.
1 Post
Much better systems out there. Do a search for PCV and you'll see lots of designs. If I believe correctly, Frost has a good one that works.
