317 heads on ls1 what push rod?
i looked around on here and saw that the 7.425 are the ones to run. i heard that 7.400 would work. anyone have solid info on this? would 7.400 work? i should be using 02+ z06 cam if that matters.
Most cams call for 7.4 push rods ( stock length ) unless you have milled the heads.
Different cams and different headgaskets will dictate different pushrods. Stock for stock they will use the same 7.400 pushrods as a stock 02 LS1.
But I am sure you will be getting a cam too............
