Intake/throttle body
trying to decide if a ls6 intake and ported throttle body will flow enough or if i need to go with a fast 90mm intake and throttle body.
my setup:
5.3 block
317 ported heads flowing 332cfm at 600 lift
234/240 @50 589 lift on a 115lsa
t-76 turbo with truck manifolds
front mount
snow meth kit
3in down pipe
any input would be appreciated, thank you
my setup:
5.3 block
front mount
snow meth kit
3in down pipe
ok that being said, about how much gain would you see from a fast 90mm and tb over an ls6 and ported tb on the above setup with lets say about 15 pounds of boost. Just trying to see if the money is worth the gain. thanks guys.
I actually got rid of my fast 92 intake for a ls6......fast intake didn't hold up for me at 16psi
https://ls1tech.com/forums/forced-in...cs-inside.html
