16psi w/ Fast 92mm Intake pics inside
Pulled my intake last week to fix a knock sensor code....turned out the two screws on bottom of intake backed out and damaged knock sensor wire....so I red locktighted the screws and put the intake back on......but check out the indentation on the bottom of the intake...I also have the right valley cover bolts
haha i feel your pain man but it might be worth it if they figure out whats wrong and send you a new one that does work right....but than again if there is something wrong with them that means i might have to send mine in...and i hate downtime!
The burst panels open around 30 psi......I guess they will only open if car backfires.....Fast wanted me to use them and they gave me a deal so I figured I would get them for the new intake, just to be safe
Edit:
Burst Panel opened around 10psi first pull with boost......I had logs to prove everything was in order........Fast gave me a complete refund and I switched to LS6 intake
Edit:
