STS oil seal problem
I ran my STS for a year with 40-70 pounds of oil preasure, well of course the oil started to force past the seals. Are the seals popped out, or just junk? What is the base turbo for the STS? Where can I get a rebuild kit? Thanks
ur scavange pump is probably goin bad.i had sts turbo and i thought the same thing and i checked w a couple people who rebuild turbos and they all said that it was my pump goin bad .
Ok, first of all there are no real SEALS in the turbo. Replace your scavenge pump with a Mocal or Exa Pump or something equivalent.
that STS scavenge pump is not nice. I just did the Exa Pump
PM me if ya have any more questions, use rear mount guys like to stick together. Everyone else is right also, replace your scavenge pump and you will be on your way
It is at the end of the oil feed line right? I remember it just has enough tension to hold back the oil when you shut off the car, right? Thanks again guys! This is great news!
so ZL1 did you add a restrictor or just change the pump?
you guys have me wondering if I was just getting oil in the pipes due to the car sitting for long periods of time (oil past checkvalve) and perhaps a pump starting to loose it's gusto.
thats the plan. Cept running a shurflo pump. im gonna put a pad of dynomat before i mount the pump..then bolt the pump down over the dynomat to dampen the sound. Then removing sts restrictor, and hobbs switches.
I can't hear my Reverso pump on high unless I'm laying under the truck when it's running. I don't understand how it is so much quieter than the STS one but it is quieter than my Walbro 255 fuel pumps.
Nice! Where can I buy a set of those! I have mine mounted to the frame, but It still makes a ton of vibration and noise...
