Found a good Engine Size and Compression Calculator
Old 04-24-2009, 06:34 PM
IT_SS's Avatar
Default Found a good Engine Size and Compression Calculator
Hiya guys,
I was doing some research compression calculations and came across a rather informative site : http://www.angelfire.com/fl/procrastination/motor.html.
You basically enter your Bore, Stroke, how many cylinders (I'd imagine you all have 8 lol), Combustion Chamber volume, Piston dome (or dish) and gasket thickness. Then hit the 'Compute' button. It seem pretty accurate, but I have yet to compare it to the actual formula for figuring CR's.
My input .::.
Piston size in inches :: 3.900" (stock)
Stroke in inches :: 3.620" (stock)
Number of cylinders :: No brain(er)
Combustion Chamber in cc :: 72 cc
Piston dome in cc's :: -2.2
(Dome = positive,
Flat = 0, dished = negative number)
Gasket Thickness in inches :: 0.052''
Output .::.
Displacement :: 346"^3 (wow, didn't see that one coming) or 5.67 LI
Compression Ratio :: 9.3.....
so it seems like a pretty useful tool....
Old 04-25-2009, 12:44 AM
Jimmy P's Avatar
Prety cool tool. Now if I could only remember what size dish is on my Diamond pistons.
Old 04-25-2009, 07:28 AM
Dumb Ass Vette Moderator
ls1290's Avatar
I have been using that one for years now. It is a very good one.
Old 04-26-2009, 01:20 AM
405HP_Z06's Avatar
It calculates incorrectly; It's only accurate within +/- .2 points. Close enough for WAG calculations considering it's free.
Old 04-26-2009, 06:37 AM
ls1290's Avatar
Aaron,
If you use the same input values as your application, it is off 0.08 in compression. Much better than a WAG. If you consider the web app does not take into account gasket diameter and others, it is pretty darn close.
Quick Reply: Found a good Engine Size and Compression Calculator
