best 16" fan ???
i bought a 16" flex- alite s-blade fan from jegs for $122 it flows 2500 cfm and then i have a 12" fan (supposedly it flows 3000cfm )yeah right
but the flexalite flowed the most for the price as far as i have seen
If that is true then I would check with SPAL first and find out extactly what the life expectancy is in hours for the model you plan to purchase. The Spal Extreme is pricey and it's not something you want to replace or very often.
Will it last as long as the stock 12 inchers which easily go to 50,000 miles plus - probably not.
If I had the room I would install two smaller pullers rather than one 16 incher.
