Can I run just mesh screens for filters on turbos??
Old 06-02-2009, 12:03 AM
KWIKKAR's Avatar
Default Can I run just mesh screens for filters on turbos??
Long story short... I'm thinking of just putting screens over my turbos, because there is no room to make inlets with these new turbos. And I dont drive in rain, down dirt roads, rocky roads, pretty much from work, dates, and racing. And I was thinking of making splash sheilds, so if I run in a puddle of water it wont splash and go in the turbos. Yeah.. let me know
Thanks Jordan
Old 06-02-2009, 12:18 AM
MY99TAWS6's Avatar
is your car a quartermile car only? Are you nuts? Do you know what the dust in the air will do to your engine, turbos etc. Man you are inhaling atmosphere like a giant hoover with those snails. Much worse than even NA and even Na guy wouldn't think of running no aircleaner or just a screen.
Are you sure you can't fit air clearners on their mabye direct to the turbos? There are lots of kinds of air cleaners. Mushroom types ,etc.
I am thinking to just get Louis 60 pounders if the are pretty much plug and play.
Old 06-02-2009, 12:23 AM
DeltaT's Avatar
Yep, SAE did a study on debris in the air and found it was the dust-level stuff that caused the most engine wear. I could see it if it were 95% track, but to work and dates? Do it right, figure out how to get some filtered air to that or it is a damn poor design.
Jim
Old 06-02-2009, 12:35 AM
elias_799's Avatar
if it is a street car do not even think about running without a filter.
unless you want you engine to
Old 06-02-2009, 10:17 AM
TurboZ28408's Avatar
filtered air > mesh screen
in terms if performance and filtration
putting a screen inlet is a lot of restriction for the turbo and you actually LOSE Power
Old 06-02-2009, 10:39 AM
KWIKKAR's Avatar
well HELL..Ok I'll figure something out
Old 06-02-2009, 10:45 AM
ScorpionT's Avatar
If you have the room, get some large diameter piping and you should be able to relocate the filters.
Old 06-02-2009, 11:26 AM
qqwqeqwrqwqtq's Avatar
Pics?
I would not run screens only in any case but especially where those turbos are located.
Old 06-02-2009, 12:38 PM
MY99TAWS6's Avatar
You should be able to just put air cleaner directly on the turbos. They have lot of different types out there. Start searching.For sure run don't run open or just screens.Or those new turbos won't last long and either will your engine!
Old 06-02-2009, 01:08 PM
FastBlackTA's Avatar
I run open screens.
It's awsome.
Old 06-02-2009, 01:27 PM
MY99TAWS6's Avatar
Originally Posted by FastBlackTA
I run open screens.
It's awsome.
And you daily drive it around like that??
Old 06-02-2009, 06:57 PM
NightHawk's Avatar
What about some of that foamy filtering material that you find wrapped around off-road and ATV filters? You could wrap it over the inlet and hose clamp it down...maybe hit it with some K&N oil to boost the filtration properties. Dunno if it would be sufficient on it own, but it's bound to be better than a screen.
Old 06-02-2009, 08:02 PM
bboyferal's Avatar
I've heard of high powered set-ups losing nearly 100 hp due to restriction on here IIRC...
Open up your average cone filter, and flatten out all the folds... Lots of area.
The metal mesh screen reduces the area of intake on the turbo quite a bit instead!
Old 06-03-2009, 01:24 AM
Louis's Avatar
I run open screens.
It's awsome.
I just giggled a little bit....
Old 06-03-2009, 05:55 AM
Dumb Ass Vette Moderator
ls1290's Avatar
And that just made me giggle a little bit
Old 06-03-2009, 10:18 AM
go on K&N's website and you can spec out a filter to your needs = large short stubby whatever they got it !
Old 06-03-2009, 12:58 PM
Old 06-03-2009, 09:36 PM
DeltaT's Avatar
You need a supporting cage to hold the foam or it will get ingested... If you can fit a cage in there you can fit a tight bend out to some filters. Those foam filters work off massive surface area too, a little sheet would either be restrictive or ineffective or both.
Jim
Old 06-04-2009, 04:57 PM
stevieturbo's Avatar
There is always room for a filter.
Old 06-08-2009, 10:04 PM
Pharm0r's Avatar
Put a paper coffee filter over it with some rubberbands and call it a day.
Quick Reply: Can I run just mesh screens for filters on turbos??
