How much boost can I run and how is this cam?
Old 06-22-2009, 11:01 PM
LS1Camaro320's Avatar
Default How much boost can I run and how is this cam?
I am building the motor for my 94 Z28 which is getting a T-trim put on it. I am putting a set of forged -22cc pistons with stock crank into a 4-bolt main corvette block. It also has ported heads. How much boost will I be able to run with this setup and how reliable will it be? Also I am trying to decide on a cam and I was looking at the 224 / 236, .502 / .520 114 comp cam. I have 1.6 ratio Crane RR's so the lift would be 535 / 554. Has anyone run this cam? How does it drive and what would the shift point be for it? With this setup how much power do you think I would be putting down with how much boost?
Old 06-23-2009, 09:32 PM
bump...anyone have any thoughts?
