HSRK on ProCharger?
Old 07-06-2009, 03:24 PM
wreckwriter's Avatar
Question HSRK on ProCharger?
I'm having major heat soak issues on my Procharged G8. I want to put an HSRK on it but not sure of the best way to mount it. General consensus of those I've asked seems to be that the standard grommet mount won't work as the boost (10 lbs) will blow the sensor out.
I'm thinking of welding a 1/2" NPT bung into the steel intake tube (last ridgid tube before the TB) then using epoxy (probably JBWeld) to attach a short length of threaded pipe around the sensor. That thread then screws into the bung leaving the end of the sensor sticking into the airstream.
Any comments or better ideas? Thanks!
Old 07-06-2009, 09:08 PM
Rickys S/C Z28's Avatar
what is this HSRK?
Old 07-07-2009, 08:23 AM
an IAT sensor.
Old 07-07-2009, 10:05 AM
allthrotle's Avatar
Originally Posted by wreckwriter
an IAT sensor.
G8's dont have iat sensors?
Old 07-07-2009, 10:15 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
It's an IAT relo kit.
Old 07-07-2009, 10:17 AM
LS1Tech Sponsor
hellbents10's Avatar
Weld a bung in with a 3/8npt and use a sensor and pig tail connector from a sy/ty.
Old 07-07-2009, 09:02 PM
o thanks
