Procharger Pulley Removal.
Old 07-23-2009, 03:28 PM
kevtherev's Avatar
Default Procharger Pulley Removal.
Removed pulley bolt but pulley held fast.Wedge screwdriver between pulley and front bracket and gave tap with hammer.Pulley does not move on shaft but pulley and shaft move out of head unit some way which seemed strange.What's going on here? I tapped it back and all seemed ok,just puzzled about movement,Any ideas? Thanks.
Old 07-23-2009, 04:56 PM
Aster's Avatar
Before you mess up the head unit grab a 3 jaw pulley puller from your favorite auto parts store. Use a small socket between the pointy shaft on the puller and the input shaft of the blower. It is a somewhat tight slip fit for the pulley and keyway, and after heat cycles it locks in there pretty good.
Old 07-23-2009, 05:38 PM
Only ERO's's Avatar
This is exactly what I did as well the other night when changing the supercharger pulley for my new SDCE setup. It worked pretty slick in getting the pulley off without putting any unnecessary pressure on the head unit.
Old 07-23-2009, 06:48 PM
blue00ZZleeper's Avatar
Hope you didnt screw the head unit up!....you probably should've looked on here before you went and did that seeing as how you didnt know what to do...hope its ok
Old 07-24-2009, 02:36 AM
kevtherev's Avatar
I was surprised how easy the shaft and pulley pulled out of the head unit.I had mangled a belt and a thin strip of it had got tied around shaft and was making a mess so I needed to pull pulley abit to get remains out.I tapped it back and it seems to idle ok(not road tested yet).Just wondered what was going on inside unit,rotor mesh etc if shaft has been pulled abit then tapped back? Thanks.
Old 07-24-2009, 09:22 AM
Aster's Avatar
The gears are straight cut so not much issue there, but the bearings they use are designed to take a load in one direction, hopefully it didn't tug one of the bearings out of place inside there.
Old 07-24-2009, 09:27 AM
JonatRLMS's Avatar
we also use a 3 jaw
Old 07-24-2009, 03:57 PM
kevtherev's Avatar
Thanks for info guy's,I'm a bit more optimistic that no damage was done and things went back with a tap of the trusty hammer!
Old 07-24-2009, 05:14 PM
jomomma's Avatar
you may have messed up the oil seal. is the head unit still in the car?
Old 07-25-2009, 08:57 AM
kevtherev's Avatar
Yeah,head unit is still in car.No sign of leak yet,will be putting some miles on car this weekend so fingers crossed.
Old 07-25-2009, 11:30 AM
forcd ind's Avatar
a little bit of loc tite gets on the shaft sometimes, better to play a small amount of heat to the pulley, should expand and come right off
Old 07-26-2009, 01:30 AM
Ryan33187's Avatar
In the directions says to heat up the pulley with a torch for a few seconds rotating around the shaft. If you hammered or put the screwdriver under it to pry it off you may have damaged the input shaft is what it says on the directions to remove the pulley from the blower.
Old 07-26-2009, 11:25 AM
tollway bandit 1's Avatar
I just use a heat gun. Comes right off.
Quick Reply: Procharger Pulley Removal.
