Granny Regal 6.0 turbo questions
thanks for all of the fantastic info that you guys have posted up here. i think ten years ago the backyarder couldnt have done as much as cheaply or easily. i have a few questions about my swap and turbo build. 1985 regal with 2003 6.0 lq4 4l80e and yet to be determined turbo.
1. can i use an iat from ls camaro(i didnt get it in harness) and where does it want to be? i am assuming cold side of turbo like my gn.
2. denali had hydroboost has anybody pulled truck version and run it?
3. motor has remote oil cooler lines. can i run a cooler and t into it for turbo
feed? do i need to restrict?
4. i want to run speed density, 4l80e (allready repinned and i will steel o2 wires and pins to use with my connecter), no vats, no rear o2 etc. i need a tuner please refer me ?
5. turbo?
i am trying to purposfully build this on the mega cheap. as it will replace my gn as my daily beater. thanks in advance robby
5. turbo?
