Vortech S trim superchargers???
Old 08-16-2009, 05:27 PM
detroit_903's Avatar
Default Vortech S trim superchargers???
Was thinking about buying a camaro with a vortech s trim supercharger on it. Does anyone here run a vortech s trim on there fbody?? I was told it dont build instant boost is that true? The car is a m6. I had a STS turbo in the past with a m6 and there was slight turbo lag after shifting into gears would the s trim do that also or will it be more instant? Also are these self contained superchargers and how much boost can the strim put out?
Old 08-16-2009, 07:58 PM
cputech's Avatar
Keep in mind that this product has been superseded and is no longer available. Information is provided here for the purpose of comparison to current products and to support existing units in the field.
Legacy Model (Superseded)
Superseded by Vortech V-1 Si-Trim Supercharger
Performance Specs
Max Speed: 50000 RPM
Max Boost: 20 PSI
Max Flow: 1000 CFM
Max Power: 680 HP
Peak Efficiency: 72%
Performance specs apply to units equipped with standard gearcase.
Dimensions
Discharge OD: 2.75"
Inlet OD: 3.5"
Discharge ID: 2.38"
Inducer Diameter: 3.1"
The industry standard supercharger
Superchargers exceeding 6 PSI require a Vortech standard bypass valve or a Vortech Maxflow racing bypass valve.
Superchargers exceeding 10 PSI require a Vortech Maxflow Mondo or Maxflow racing bypass valve.
Old 08-17-2009, 12:13 AM
DeltaT's Avatar
The boost rises in direct proportion to the rpm of the motor. It does make some boost off idle, but doesn't start getting noteworthy until around 3000, solid midrange and a stout top-end.
These are not self contained units, they must be fed engine oil and have a drain punched into your pan at a specific point, but it isn't hard.
Yshould be able to get well into the 5xxrwhp range with an S-trim and an intercooler, perhaps low 600rwhp.
Best compression ratio is probably in the 9.5-10:1 range with a good IC. Throttle response should be very sharp with a proprer tune.
Jim
Old 08-17-2009, 09:49 AM
YSILT1's Avatar
The Vortech Si -Trim is 1150 CFM and has a 3.62 step up ratio.
Old 08-20-2009, 12:57 AM
DeltaT's Avatar
The Si-trim is available in V-1 and V-2 versions, the V-1 has a step-up ratio of 3.42:1 and the V-2 (Superquiet) gearbox has the 3.62:1 ratio.
Jim
Quick Reply: Vortech S trim superchargers???
