best cam for a disc
Old 08-27-2009, 11:45 AM
CHRIS'S 98 SS's Avatar
Default best cam for a disc
as the topic states, and i will be running 10 psi of boost with a build forged bottom end motor. I am going from na to boost. its a 347 ci motor and imput on heads is appreciated. Many cams out there and just want to know what u have and the power your making.
Old 08-27-2009, 11:50 AM
sujomatt's Avatar
EPP Blower Cam?
Old 08-27-2009, 11:54 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I have had god results with the speed inc SC2 blower cam. I hear lots of others having good results with the EPP one as well. I wouldnt be hesitant to use either.
Old 08-27-2009, 12:22 PM
i was leaning toward the epp cam but was wondering what other cams are making power.
Old 08-27-2009, 12:53 PM
LS1Tech Sponsor
Slowhawk's Avatar
Alot of Cams make power with boost.Comes down to personal preference.Our populer Cam is a 220 Cam because it's 100% stock drivability with the potential of hitting 700+rwhp with a 346/D1 pump gas setup.
Old 08-27-2009, 01:11 PM
now thats what im looking for, do you have any dyno sheets with this cam you recomend
Old 08-27-2009, 10:45 PM
WHPLASH's Avatar
My LG cam made a world of difference over the GT2-3. Unbelievable difference.
Old 08-28-2009, 06:35 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com...html?item=1109
KP proved our cam works, although he could probably get any cam to work! lol Bob
Old 09-04-2009, 08:58 AM
BriancWS6's Avatar
Bob, all the links for the videos haven't worked for quite sometime. Just a heads up if you weren't aware, which I wouldn't think you'd post them up if you knew.
Old 09-04-2009, 11:08 AM
Customizing Director
MadIceV8's Avatar
Few cams that I've researched and recommend you take a look at. I ended up going with the Futral F7.
Futral F7
Speed Inc SC2
EEP Blower Cam
Old 09-08-2009, 08:00 AM
EPP
EPP's Avatar
Thanks, I didn't know it. Bob
Quick Reply: best cam for a disc
