408 Truck Manifold Build
looking for input on turbo build. lq9 block, diamond pistons, compstar crack, compstar rods, manley timing chain, total seal rings, melling oil pump, compcam, gm lifters, gm gaskets, arp bolts, need input on heads, found a set of patriot performance 6.0 head $ 600.00 good deal or not??? need input on intake i have a shock intake and a bbk intake good or bad.transmission is a turbo 400 do i need transbrake?? what gear is needed in rearend?? what type of engine management is needed to run engine fast or big stuff. i want to run 6.5 or better in 1/8 mile. have pic posted, dont know how to place on thrend. check under fludd704
