What do you guys think?
Old 09-20-2009, 01:14 PM
boostnificent's Avatar
Default What do you guys think?
What do you guys think? Anyone running anything similar?
Displacement: 395ci
Compression: 8.7:1
Bore: 3.903 in.
Stroke: 4.125 in.
Rod Length: 6.125 in.
Dome Volume: -30 cc
Compression Height: 1.050 in.
Ring Sizes: 1.5-1.5-3MM
AFR 215cc
Ported FAST 92mm w/ 92mm TB
Single 76mm turbo T4 .96 A/R
Plan on having a cam custom ground for this setup.
Old 09-20-2009, 01:22 PM
The Beast's Avatar
Displacement: 395ci
Compression: 8.7:1
Bore: 3.903 in.
Stroke: 4.125 in.
Dome Volume: -30 cc
AFR 215cc
Turbo is to small for the motor or the motor is to big for the turbo. Take your pick.
Old 09-20-2009, 01:54 PM
i've seen alot of people running 6.0 with these turbos. is it the compressor side that is too small?
Old 09-20-2009, 02:06 PM
jay_rich's Avatar
your gonna want a T6 flange for your cubes. I run a Garrett T6 flange 74mm on my 383, the upper rpms the car puls like crazy...picked up 36RWHP from6170-6250rpm.
Mine is off a detroit diesels semi truck ...does its job great for a 300 dollar brand new rebuilt turbo!
Jay
Old 09-20-2009, 10:20 PM
well iguess i'm going to have to stick with my original plan and have tt 76's. what about the heads? if i step up to 225's won't i have shrouding issues?
Old 09-20-2009, 10:53 PM
blk00ss's Avatar
They make "small bore" 225's.
Old 09-20-2009, 10:55 PM
ta02zx10r's Avatar
twin's are expensive! I'm taking that shot to the pills as we speak. I almost wish I had never done it and I haven't even done the install yet! You'll be a professional parts collector before it's all said and done. Big singles give ya some lag and lag is traction. I fell for the ole twin deal and instant spool. I'll never hook on the street. Looks like I'll have to just play with the supra's on the interstate. Wait a minute there aren't any in Wyoming. Well look out cummins and duramax lol. Good luck nonetheless. Chris
Old 09-20-2009, 10:56 PM
MelScrilla's Avatar
if you already have the kit just get a bigger downpipe and a t6 flange, I wouldn't do twins because your gonna end up spend spending more money than if you went with a big single. A 88mm would be about right for your setup and 2 76's will probably be way to much.
If one 76 supports 800hp(estimate) than 2 will go for 1600hp. and exhaust from one side of your engine probably wouldn't spool a 76. Full blown race cars run 2 76mm's and go deep in the 7's. If your going to run 2 for the street 2 67mm t3's would probably be more than enough.
Old 09-20-2009, 11:13 PM
ta02zx10r's Avatar
the tc units (76's) that turbonetics makes will spool just fine. check out tiago's setup and I think he's on a 402?
Old 09-21-2009, 12:31 AM
you know i've probably looked at those heads a hundred times and never noticed that they made those. i went back and looked and noticed the flow chart with the 3.900 bore. thanks for the heads up.
if you read this article on Tim Lynch's street car, i know it is a Ford, but he has a 362ci with twin 76's and makes 1308hp at the back tires. why wouldn't it work for my set up? http://www.musclemustangfastfords.co..._lx/index.html
Old 09-21-2009, 10:11 AM
blk00ss's Avatar
I'm sure he has a lot more cam and heads than you can work in your budget. Things that will help spool.
Old 09-21-2009, 10:28 AM
Cobra Huntter's Avatar
get a lager ar. Im going to run a 1.10ar. So like they all said big turbo like a 80 somthing
Old 09-21-2009, 12:30 PM
he has a set of ported TFS Twisted wedge heads on it. I'm sure Tim and Steve Petty ground a custom cam for it. Why wouldn't those items be affordable? I had planned on sending my heads to TEA and having a cam ground for my set up.
Old 09-21-2009, 01:15 PM
vetteguy130's Avatar
larger ar
Old 09-21-2009, 01:29 PM
RS_SS69's Avatar
Go at least 88mm turbo, look at the garret gt-88. The sponser forcedinductions sells it for $1249. Very good priced and will support 1400 hp flywheel and 1000 rwhp thats a t-6 flange and its a small $250 more than a tc-76 or 78. The t-6 flange will allow you to grow more for future upgrades. Go with the 1.08 a/r if your wanting it to spool faster and be more streetable. Just got off the phone with them and thats what they said for my setup which is similar.
Old 09-21-2009, 03:31 PM
Restricted User
98Z28CobraKiller's Avatar
That's WAY too much stroke for a stock sleeve AND ANY POWER ADDER. I'm surprised that no one has said anything yet. That thing is gonna drink oil like it's going out of style.
Old 09-21-2009, 03:41 PM
omore001's Avatar
What he said... 395 for radical N/A or low boost
Old 09-21-2009, 04:08 PM
thanks man this is the kind of info i am looking for. I'm fairly new to GM motors. with a 351 windsor this wouldn't be a problem. i have a friend that has a 6.0 he wants to sell me. with the current turbo i have what would you guys recommend for the 6.0?
this is my first turbo build and i am trying to learn both the turbo stuff as well as the GM stuff. so if i ask what seems like a dumb question i'm sorry. i appreciate all of the info and help.
