oil feed/supply -where to get???
Old 10-02-2009, 12:06 AM
71 chevy's Avatar
Default oil feed/supply -where to get???
hi, Im using an aftermarket pans with no built in provision for pressure feed.
is there anywhere on the block (5.3 iron block) where I can get the oil feed from? or do I have to tap the pan?
sorry, first time doing this
Old 10-02-2009, 06:19 PM
koolrayz's Avatar
you can get it at the oil pressure sensor. Look on Kurt Urbans website he sells an extension with ports
Old 10-03-2009, 12:02 AM
383lt1impala's Avatar
i need to know the same i have a moroso pan with a filter relo kit and twin turbos.
Old 10-03-2009, 12:49 AM
71 chevy's Avatar
is this what you speak of?
http://www.kurturbanperformance.com/...t-adapter.html
I dont have an engine yet, do you have a pic of where it actually mounts to?
Old 10-03-2009, 08:30 AM
koolrayz's Avatar
I dont have a pic. It goes where the oil pressure sensor goes. With the four port version you can still use the factory sensor
Old 10-03-2009, 08:49 AM
71 chevy's Avatar
let me ask this. is it possible to just tap the oil pan somewhere for pressurized supply?
Old 10-03-2009, 10:12 AM
TX RED's Avatar
right over the oil filter you can drill and tap it, let me see if i can find the pic
Old 10-03-2009, 02:14 PM
71 chevy's Avatar
thats only for chevy pans, not aftermarket, so it wont work.
Old 10-03-2009, 02:35 PM
TX RED's Avatar
Read right over that sorry
Quick Reply: oil feed/supply -where to get???
