k-member for turbo app
Old Oct 2, 2009 | 10:17 AM
cfon159's Avatar
Default k-member for turbo app
im deciding on boosting my 02 ta and just wanted to know which k-member would be best to allow for routing of the hot pipes? ive been reading that some ppl go over, many go under, and some dump before or right after. i plan on using the ebay tubing and custom intercooler kit. so far im set on the bmr turbo style member, unless one of the others allow for more room.
thanx
Old Oct 2, 2009 | 10:30 AM
Steve Burger's Avatar
LS1TECH Sponsor
Ours are very roomy but do require the use of motor plates.
Old Oct 2, 2009 | 10:55 AM
veee8's Avatar
The turbo BMR is pricey, the regular BMR is not turbo friendly.
I have used the PA kmember with Spohn solid mounts, able to run a 5" downpipe along the block and motor mounts. I believe it is $300 for the mild steel PA, another $200 for the Spohn mounts. If you use a BMR you are stuck with stock type motor mounts.
Old Oct 2, 2009 | 11:31 AM
blazin's Avatar
IS there room to run a pipe beside the ac compressor with the pa racing k member? like a 2.5 in pipe on a twin setup?
Old Oct 2, 2009 | 01:26 PM
veee8's Avatar
My headers were up high, but here is a crappy pic showing that area. That is 5" pipe.
Old Oct 2, 2009 | 01:54 PM
cfon159's Avatar
ur right bout the price, and it does look like urs i pretty roomy. dont think ill be using solid mounts tho. think im gonna keep 3". its is my dd too. thanx
Old Oct 2, 2009 | 05:57 PM
blazin's Avatar
Its amazing how harsh people think solid mounts are. I love mine solid mounts kick *** for clearence and everything else. vee8- its hard to imagine a compressor on there what do you think?
Old Oct 2, 2009 | 08:53 PM
veee8's Avatar
Probably not with 5", but I am sure you could do something, and retain a/c there.
I just finished up a build on nnracing's car, he had a standard BMR with new GM mounts. I had to jack the motor off the mounts, and grind/cut the block just to fit a 3.5" through there. Then set the motor back down with the pipe laid in place, it is not coming back out easily. It was a joke, there was definitely some cussing involved. A lot of screwing around for little 3.5" pipe. In the end the motor rocks around quite a bit.
Solid mounts, are a great addition to a turbo car in my opinion. Even a street car.
Old Oct 2, 2009 | 09:26 PM
blazin's Avatar
I was thinking a 2.5 inch pipe.
Old Oct 3, 2009 | 03:36 AM
evilZO6's Avatar
Does a designated turbo K member make it easier to keep your AC?
Old Oct 3, 2009 | 08:25 AM
ls2 bait's Avatar
the turbo unit is only $100 more then the standard from bmr? with this level build is $100 really going to break the deal? im just asking.
Old Oct 3, 2009 | 02:31 PM
DanZ28's Avatar
The BMR turbo K-member is the roomiest I've seen fits 5" easy, and great quality.
Old Oct 3, 2009 | 03:03 PM
WS6HUMMER's Avatar
I'm really happy with my BMR turbo K member, I just run a 4" DP though
