Radix Magnacharger + Heads + cam ?
Ill be getting a radix magnacharger in the next few days, I was going to go N/A but found this instead.
Ive got heads (stock ported ls1 heads) and a cam (MTI X1) sitting in my garage. should i just sell this stuff and only install the supercharger, should I sell the cam and go with a blower cam?
How much power could I expect to make with say a 2.9 pulley, those heads, and a cam?
I don't have a clue what an MTI X1 cam is, but with a 112, I'd opt for a pretty conservative grind. I like the LS6 cam in my rig. I had a bigger cam previous to the LS6. It "might" have made a little more power on the top end, but I doubt it. If you had a bigger blower on top, more cam could equal more power. In your situation, I don't think that's the case.
My maggie experience is with front drives. 2.9" on a front drive should get you around 500 at the wheels (manual tranny) if you have a good intake and exhaust. Should get you close to that tq wise at around 2500 rpm.
holy cow 500 rwhp? ok, sound like selling the heads would be the way to go, thats more money I can spend on other things like a gauge pod. the cam i might sell and trade for something with a 118lsa or more. I heard the lingenfelter G7? is a good FI cam. but I could go with a ls6, Ive got a 3.0 pulley for it, im full bolt ons too.
I wouldn't spend money porting heads on a 112 blown LS. I'm assuming 5.7 to 6.0L engine size. However, if you have them, I'd sure use them. Probably not a whole lot of extra power, but boost should go down with better heads. Less boost with the same size drive pulley is all good. Less boost equals less heat and could allow more timing.
