STS Turbo setup - question on Cats
Old 11-10-2009, 11:22 AM
sujomatt's Avatar
Default STS Turbo setup - question on Cats
I am sure someone is gonna yell at me to do a search but I believe my situation is a bit unique - here is why:
I have Pacesetter 1 3/4" long tubes and a 3" catless y pipe right now.. All heat wrapped and sprayed to the turbo. The turbo is a T67....
Now - I want to upgrade the turbo to a T76 and at the same time bring up the spool time a bit.. In this situation i'd like to avoid taking the headers off and y pipe off... Would a metal-core high flow cat bring the temps up enough to see it spool sooner? I was thinking of doing a hot side in the .80 range ... Thoughts? (other than telling me to go back to stock manifolds lol)
EDIT: this is because I may be doing a forged bottom end in the spring, trying to get an idea
Old 11-10-2009, 11:27 AM
hawk584's Avatar
you don't want high flow, you want stock exhaust manifolds w/heat wrap which has a higher/faster velocity of exhaust flow to spool the the turbine faster and the cast iron holds the heat much better. kinda like a garden hose with our thumb on the end vs. 3'inch PVC piping and your hand over the end. you will see a significant difference in spool time and little to no lag with manifolds
Old 11-10-2009, 11:39 AM
sujomatt's Avatar
.... did u miss what i posted? lol
well with what u said - ill ask this: what r u doing for a y pipe? and did you port the manifolds? I have a beefy cam 232/240 .595/.608 115.. don't want it to have no where to go lol - but if the exhaust flows faster i guess there wouldnt b a problem
Old 11-10-2009, 11:54 AM
hawk584's Avatar
stock y-pipe, ported/polished stock manifolds. i missed that you are in CT. yes, high flow cats i would recommend. i've heard stories of stock cats breaking down and throwing chunks of the cat into the turbine fins damaging the turbo. i don't know much about cam specs
this is close to what i have but for an LT1: http://leperformance.com/leplsxturbo...rcamshaft.aspx
Old 11-10-2009, 12:03 PM
sujomatt's Avatar
yea i think ill try that - i just wish i kept my mac 2.5" y-pipe that was catless which bolted up to stock manifolds lol
now with that said - if i swap to that, what size hotside on the t76 turbo? ill be using meth on a stock bottom end until it blows up or till i have more money lol
Old 11-10-2009, 12:09 PM
hawk584's Avatar
there's a guy here in utah with a bone stock LS T/A t67 sts kit & headers. he said he got the kit for cheap and was thinking about selling it because it didn't make much power (link in my signature). he got a ride in my hawk and it made him think twice
Old 11-10-2009, 12:13 PM
sujomatt's Avatar
i no doubt love the system - just takes time and a lot of work.. just want some additional info so its done right this last time around lol
was trying to avoid another PITA swapped exhaust parts, but after a while u kinda realize u gotta..
Old 11-10-2009, 12:22 PM
hawk584's Avatar
done right is the right mindset ! this is the kit i'm running with my little LEP forged 385cu.in LT1. this is my first turbo one time tuned at just over 500. now that i am conferable i'm shooting for the 600 mark this summer. my friend in vegas is running pretty much the same with his 2002 SS. when he had the t67 LEP got it up to 530 rearwheel on 100oct. with a nearly bone stock LS# and now with a forged motor he's pumping out over 630 safely and neither i or him have had any major issues. most i've had is hose clamps coming loose
http://leperformance.com/lepstsrearmountturbo.aspx
Old 11-10-2009, 12:24 PM
sujomatt's Avatar
how much boost r u guys running? 8psi?
Old 11-10-2009, 12:27 PM
hawk584's Avatar
i dont know about him but i'm at about 10. lt1's act a bit different then LS's i believe and he's on 100oct. i think he was at 10psi @530rwhp
Old 11-10-2009, 12:30 PM
sujomatt's Avatar
i guess my concern is also the idea of losing power - i dont want that to happen..
Anyone else know if i would as well?? or if id keep the power now but have it come on sooner??
Old 11-10-2009, 12:54 PM
OUTLAWZ RACING's Avatar
You could try a smaller y pipe to help reduce the surface area of heat loss. Plus it will creat a velocity typ deal.
Old 11-10-2009, 01:00 PM
sujomatt's Avatar
so like long tubes to 3"-2.5" y-pipe, back up to 3" for the intermediate pipe?
Old 11-10-2009, 05:54 PM
2nd Gen Fl 'bird's Avatar
I see your good numbers. What size are your y and I pipe? I agree with the smaller pipe for less surface area idea. That being said, most people run 2.5 pipe from manifold to turbo. What do you think about 2.25 y pipe then 2.5 for the I to the turbo? The manifolds I've measured have a 2" exit. Doesn't make much since to go straight to 2.5 straight off the manifold, just trying to get others theories on this.
Old 11-10-2009, 08:02 PM
Did u install a 3 inch cat back? The stock I pipe on the f-body is like 2.59 not exactly three inch. But my exhaust used the stock I and 2.5 y and stock manafolds
I run stock manafolds to a 2.5 y and the stock I pipe 2.59 to the turbo. The only three inch stuf is on the cold side.
Old 11-10-2009, 08:05 PM
also 2.5 seems to work just fine any smaller I have no Ideal. The biggest restriction in the system will be the turbo, But in theroy the 2.25 should spool it faster with less surface are cooling but im not sure of the power trade off.
Old 11-10-2009, 08:52 PM
sujomatt's Avatar
well them im makin the change - bout damn time too lol
Old 11-11-2009, 07:24 AM
sujomatt's Avatar
Hey Outlaw, what motor and size turbo do u have and all that stuff? and what was ur 1/4 ET, etc?
Old 11-11-2009, 11:32 AM
4xx for the haters lol gts 76 .81 hot side, the highest hp was 813 at 17 psi 14 psi was 760. Best quater since I only ran it twice was a 10.38 142 on a street tire 1.78 short time if i remeber correctly not sure 16 psi. The run befor that was a 11.23 at 136 with a 1.9 short time. The track prep was awsome alot of cam only vettes where low 11 to mid 10s on dr all day. Nothing special epp blower cam patriot stg 3 heads arp studs stock 10 bolt with hardern axels and 3.73 gear meth injection vic jr dual intank fuel system custom cold side custom true Y pipe, and header wrap.
Old 11-11-2009, 01:17 PM
sujomatt's Avatar
i have 99 manifolds - the more restrictive ones, did u port urs outlaw?
Quick Reply: STS Turbo setup - question on Cats
