70mm turbo
70mm turbo
I have a stock ls1 with single turbo kit from hinson is the 70mm turbo to small or would a 76 mm be better for this application this is a every day driver with no stall converter.
Im running a t70 from Master Power, so is 1BadLS1. Basically when you max out the turbo you should be somewhere in the neighborhood of 600whp if not more. It really depends on your goal. If your goal is 500whp, you would be better off stick with a smaller turbo that will spool faster.
thanks for the reply my goal is 500 rwhp so the 70mm will be the best route to go and spool faster .I can always step up to the 76 when i get ready to build a forged internal LS1.
