d-1 max impeller speed.
Old 12-08-2009, 12:27 PM
pontiac455cars's Avatar
Default d-1 max impeller speed.
I have a 4.25 pulley on a d-1,making about 9# at max rpm,I want to install a 3.85 to increase boost.Will I over spin the d-1?
Old 12-08-2009, 12:32 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
what size crank pulley? What engine RPM? Your impeller RPM is the crank pulley diameter/ head unit diameter * engine rpm * step up ratio of the blower.
Old 12-08-2009, 12:42 PM
Chad,it is the exotic perfomance race kit.I beleive the crank is 7".Its the super dampner.It is a stock bottom end I spin to 6300 rpms.
Old 12-08-2009, 01:49 PM
BriancWS6's Avatar
Your no where near over spinning it with that setup. The D1SC max impeller rpm is 62,000. What your wanting to do will only be 51,324.
Old 12-08-2009, 02:07 PM
ChevyChad's Avatar
Well, if you have the standard 8 rib procharger crank pulley that attaches to the ATI superdamper with the 3 bolts, you most likely have a 7.65" crank pulley.. But as mentioned, even with the 7.65/ 3.85 combo, you would be at 51324.5 impeller RPM, which is only spinning it to 82.78% of its max potential. To max a D1SC out, you would need to use a 7.65/3.4 pulley combo, and spin the engine over 6700RPM.
Old 12-09-2009, 05:00 AM
EPP
EPP's Avatar
It is indeed the 7.65 diameter on the crank pulley. Bob
Quick Reply: d-1 max impeller speed.
