Factory style 3 bar map sensor
Is there such a beast? Problem is I'm using that Edelbrock Pro flo intake and it has a hole machined in it for a stock style map. It would be nice to be able to bolt one up.
Thanks,
Frank
Thanks,
Frank
Three bar map sensors
GM Style 3 Bar Pressure Sensors
Manufacturer Part Number
GM (old)* 16040749
AC Delco (old)* 213-101
GM (new)** 12223861
AC Delco (new)** 213-1562
MSD** 2313
MSD (compact)** 23131
Borg Warner** EC1678
NAPA CRB219481
Electromotive Engine Controls 71130
Holley 538-23
From the Turbo FAQ
GM (old)* 16040749
GM (new)** 12223861
MSD** 2313
NAPA CRB219481
Holley 538-23
From the Turbo FAQ
Thanks, I did read that, but I'm looking to find out if there is a factory style sensor that is 3 bar. In other words one that would go into the factory location like the 2 bar cobalt ss sensor.
I did notice that the Duramax engines have a 3.3 bar map that looks like it may fit. Anyone know about these?
Thanks,
Frank
Thanks,
Frank
Tap the hole in the intake manifold with a 1/4 pipe tap and get a fitting that goes from 1/4 pipe to a 1/4 hose, get a piece of hose and use it to connect the map to the adapter! Bada Bing! Oh it works.. done it to a few cars.
I'm thinking I may end up doing something like that. I will just block that port with a pipe plug and use one of the other million port they put on this intake.
Delphi 2 bar - 09350899 (common 2.4/EcoTec S/C MAP)
Delphi 2 bar - 16235939 (same sensor as above)
Delphi 3.3 bar - 09373269 or 12215049 (same style sensor as above)
Delphi 3 bar - 12223861 or 12219935 (fat style sensor, like the GTP/Turbo Sunbird)
http://www.powerandsignal.de/docs/Products/09350899.pdf
http://www.powerandsignal.de/docs/Products/16235939.pdf
http://www.powerandsignal.com/docs/P...s/09373269.pdf
http://www.powerandsignal.com/docs/P...s/12215049.pdf
http://www.powerandsignal.com/docs/P...s/12223861.pdf
http://www.powerandsignal.com/docs/P...s/12219935.pdf
You are the man Jontall
Looks like that 3.3 bar sensor is the hot ticket! You guys think there is any difference between responce times or sensor quality etc. between the old style 3 bar and the new 3.3??
All you have to do is find out the new outputs are (ABC) which is ground,signal and 5v input. Run the wires properly. If it came with a plug just splice apporparitly.
booyyahhh thats what i was gunna say get the drill out and go to town haha
