L92 Heads - how much boost possible?
What is a reasonable maximum amount of boost a set of L92 heads could handle before lifting? Assume using an iron block and ARP studs.
Go with a set that has thicker decks. Try a search, I'm pretty sure I remember reading a couple threads on this. Your better off going with AFR'S, ported 317's or 243's as the deck thickness is better. ARP studs help with a higher clamping force but avoid the heads all together.
