female fan conector
female fan conector
i need to wire up two spal pusher fans and i really do not feel like cutting the factory plug that is on the main harness and wiring them without a connector
does anybody have a part number of the female plug or at least confirm the existence of it ?
You can just put two non-insulated male spade connectors on your spal wiring and pop them into the factory plug, that's what I ended up doing. Factory connector is unharmed and you can unplug/switch around the wiring at will.
