broke crank / need a crank support
Old 03-01-2010, 01:02 AM
hawkls7's Avatar
Default broke crank / need a crank support
I think due to belt tension or other , my callies crank has snapped after the front cap just before the first rod near the shaft. damage seems minimal, but now it has me worried if i replace the crank that it will happen again . i have read that it is common for f1 applications to brake cranks , is this the common area where they brake? my questions are : what would you replace after this failure , or what would you do to resolve this issue . Im thinking of building a crank support or are there any available for the war hawk block . my belt was a gilmer set up . a picture of set up below.
Attached Thumbnails broke crank / need a crank support-super3.jpg
Old 03-01-2010, 02:43 AM
EPP
EPP's Avatar
Crank breakage is very rare in these engines, I've never seen it happen myself. Are you sure that croc in your avatar didn't bite a chunk out of it? We've used a lot of ProCharger F-1A through F-1R systems and have never had a problem with crankshafts. Bob
Old 03-01-2010, 04:01 AM
BLOWNBLUEZ06's Avatar
Originally Posted by EPP Automotive Performance
Crank breakage is very rare in these engines, I've never seen it happen myself. We've used a lot of ProCharger F-1A through F-1R systems and have never had a problem with crankshafts. Bob
Even with cogs Bob? I am thinking that's where the additional stress is coming from.
Old 03-01-2010, 06:43 AM
OUTLAWZ RACING's Avatar
Can you post a pic of the crank? Maybe a front bering went caused some heat and it just gave? Im no expert tho.
Old 03-01-2010, 07:13 AM
hawkls7's Avatar
Front bearing has more wear on outer face closest to pulley,but has not spun. I still had full oil pressure,very luky not on full song when it let go felt a vibration that initially I thought it was the auto trans but on futher observation I noticed a slight oil leak from the front seal ,so out came the engine.
Old 03-01-2010, 07:23 AM
So did it walk and push the seal out? Forgive me Im just trying to learn summin here. Or did the stall push it?
Old 03-01-2010, 04:34 PM
hawkls7's Avatar
no it did not walk , the seal leaked due to the extra play at the snout
Old 03-01-2010, 04:47 PM
crashinaz's Avatar
A cog drive is going to do that, but tensioning the hell a ribbed pulley won't? I seriously doubt it's tortional load being applied by the blower if it broke BEHIND the #1 cap (between the journal and counterweight I assume is where you're speaking) unless it was a manufacturing defect from the start. I'd REALLY like to see a macro of the break.
Old 03-01-2010, 05:09 PM
hawkls7's Avatar
bob , being a quality crank from callies i did not think it would crack , but ive read on this forum that they are common to break at the same posi where mine broke.
Old 03-01-2010, 05:26 PM
Shawn @ VA Speed's Avatar
which Callies crank was it?
Old 03-01-2010, 07:37 PM
daniel6718's Avatar
post pics
Old 03-01-2010, 08:30 PM
hawkls7's Avatar
it was the callies dragon slayer 4 inch
Old 03-01-2010, 09:14 PM
hawkls7's Avatar
Originally Posted by daniel6718
post pics
pics of damage
Attached Thumbnails broke crank / need a crank support-crank.jpg   broke crank / need a crank support-photo.jpg
Old 03-31-2010, 01:15 PM
speedracer5532's Avatar
So what do you think caused this? Did you try to change anything to prevent it from possibly happening again?
Old 03-31-2010, 06:47 PM
t-1
t-1's Avatar
there is a guy in denver who can fix stuff like that. guy is almost mythical but the most reliable sources i know swear buy him. he fixed a lunati crank i bent for half of new.
Old 03-31-2010, 06:52 PM
BigRich954RR's Avatar
What procharger u running ?
Old 03-31-2010, 07:26 PM
hawkls7's Avatar
Wink
the cause of the brakage is obviously at a weaker spot which is common to occur i hear but knowing why? is another issue . My thoughts would be in testing the metal propertys firstly. But the proper testing is quite expensive like 10000-15000 basic testing can be done for 500 but the real diagnosis of why it broke with proper testing is the later.
Callies is producing me a crank that will be stronger in this area so time will tell.If there is enough room up front i plan on constructing a custom crank support, which will also give me more safety, unless there is one out there that fits the warhawk block let me know it will save me heaps of time. the supercharger that i am using is the vortec ysi .
Old 03-31-2010, 08:00 PM
Race your car!
JL ws-6's Avatar
This would be a good time to put a crank in with a BBC snout too, so that you have the additional strength there.
Old 03-31-2010, 08:40 PM
hawkls7's Avatar
Thumbs down
the snout never broke off .
Old 03-31-2010, 11:02 PM
elias_799's Avatar
i have never seen a forged steel crank break, there had to be a defect somewhere
Quick Reply: broke crank / need a crank support
