Nitrous with turbo
Nitrous with turbo
i have a tti turbo kit with a t-60 turbo. how big of a shot can i use to spool the turbo?? and will the nitrous keep detonation down? inform me.....
as far as keeping detonation down yes and no
if you keep the air cooler coming in yes it does help with detonation but on the other hand when you compress air you create heat and the more air the more heat
Restricted User
+1. You have a problem if you aren't instantly spooling a T60.
Also, nitrous is not what you want to keep down detonation.
Race gas or meth injection is what you are looking for. The only thing that nitrous would be usefull for on an ls1 t60 setup is to stretch out the top end.
