6 bolt ls2
6 bolt ls2
I'm building a motor looking at 1,500+ HP using a f2, iv seen where people have made a stock ls2 block into a 6 head bolt block by adding some sort of plate, does anyone have more info on this?
ERL makes one of the best LS2 6 bolt blocks you can buy. Take a look www.erlperformance.com What you had mentioned above about the plate sounds like the superdeck II system ERL makes. Alot of street guys use the superdeck I. David Childress (MIghtyMouse) uses an ERL 6 bolt LS2 in his 8 second trans am. I just ordered a similar setup today!
Not cheap, but cheaper than buying a new 6bolt block then getting everything machined again... Cheapest bet is going to be the LSX but I've heard it cost more than normal to get everything machined correctly...
shawn @ va speed has designed a modified LS2 with 6 headbolts, a much thicker deck, and then some...its going to be the foundation of my new 2000+ hp setup
http://www.yellowbullet.com/forum/sh...d.php?t=226130
