Does an exhaust crossover matter under boost?
Old 04-15-2010, 09:45 PM
onefastmx5's Avatar
Default Does an exhaust crossover matter under boost?
I'm going to go true duals once I get my car boosted. I'd like to keep it simple and go straight back from the headers and over the axle. I understand most people use an X or Y pipe for backpressure/scavenging. How much HP will I lose not having a crossover. It'll be so much easier/cleaner not running one, but if its going to hurt numbers too much, I'll figure a way to run an Xpipe.
Thanks!
Old 04-16-2010, 09:21 PM
Uglydog56's Avatar
A crossover or x-pipe needs exhaust pulses to scavenge effectively. Downstream of the turbo, the exhaust pulses are pretty much "chopped up" by the turbine wheel, there are no realistically no pulses left. There is no gain to running an x-pipe post-turbo. Just make it smooth and free-flowing and you should be good.
Old 04-16-2010, 09:59 PM
XtremeDime's Avatar
He has a Vortech not a turbo.
X pipe should be fine.
Old 04-16-2010, 10:33 PM
onefastmx5's Avatar
Thanks, found what I need then-> http://www.summitracing.com/parts/BIG-53631FLT/
Old 04-16-2010, 11:58 PM
Restricted User
98Z28CobraKiller's Avatar
It will help on a blower car. It is also a good place for a WBO2 sensor to get an average3 reading from both banks.
Old 04-17-2010, 02:38 PM
Uglydog56's Avatar
oops you're right. Should have read the sig. Definitely get the xpipe.
Old 04-17-2010, 08:06 PM
onefastmx5's Avatar
Thanks all, going with summit Xpipe + Magnaflow 4x9 mufflers.
Quick Reply: Does an exhaust crossover matter under boost?
