Where to hook up a oil pressure gauge on a Warhawk block
i know on the ls2 i think there a plate by the oil filter you can drill and tap for a oil pressure gauge.
But on the Worlds Warhawk block where the best place to hook up a oil psi gauge ?
The block off plate on the oil pan how thick is that. going to pull that off and tap that to get oil pressure off of and maybe a oil temp sensor too if there room.
But is there a block off plate premade for this on a GTO 06. I think the 2006 GTO oil pan had two spot to tap oil off of ?
