How to DIY build a truck manifold turbo kit!
Old 08-12-2010, 04:56 PM
  #61
UberTruck's Avatar
Originally Posted by edtuner
im 19 and im performing a ls1 swap in my lexus is300, i also am doing the work myself and would also like to learn how to weld.
pics!
Old 08-14-2010, 05:49 PM
  #62
KILLER-LS1's Avatar
Originally Posted by UberTruck
Hey Killer!, Great write up man.
What kind of fuel system are you using? I'm pretty much putting all of this together in my driveway, and a friend of mine and me are like, "what are we going to do for a fuel system?" I looked at him, and was like, "Havent thought about that yet..."
Most people take smoke breaks or food breaks or whatever...
...WE take ls1tech breaks. hhahahahahahahahaha.
So far I'm probably going with Nasty Performances Single Pump hotwire kit, but if everyone would rather see it get duals it will.
Thanks! I'm running a dual Walbro in tank with russel -8 feed and -6 return, with an Edelbrock boost referenced fuel pressure regulator. Also seimens 83 lb/hr injectors. I think you should do the nasty dual set-up, the last thing you want to worry about is having enough fuel.
Old 08-17-2010, 02:59 AM
  #63
UberTruck's Avatar
thx man
Old 08-17-2010, 11:03 PM
  #64
KILLER-LS1's Avatar
So far the new moser is working perfectly!! Ill post pics of the new rear soon
Old 08-23-2010, 10:56 AM
  #65
Josecristo's Avatar
I've been wondering how can i do a truck manifold turbo and keep the a/c
95% of the post says "A/C got to go"
Anybody out there with truck manifolds and A/C??
Old 08-23-2010, 11:57 AM
  #66
merim123's Avatar
i think it's because the truck manifold goes where the A/C compressor would be. The c6 manifolds are supposedly better, can't confirm, haven't found a build with those and a/c yet.
Old 08-23-2010, 04:14 PM
  #67
KILLER-LS1's Avatar
No, the truck manifold is right in the way of the A/C. Your only option would be to run a stock or c6 manifold facing the rear of the car on the passenger side. you would then have it loop toward the front of the car, going UNDER the k-member, but this greatly reduces clearance.
Old 09-03-2010, 06:22 PM
  #68
KILLER-LS1's Avatar
Updated dyno numbers through my Moser 9"
Old 09-03-2010, 06:36 PM
  #69
KILLER-LS1's Avatar
http://www.youtube.com/watch?v=MGomzGtnLKg
Another dyno vid showing spool time
Old 09-10-2010, 02:39 PM
  #70
bravoboost's Avatar
Very interested in going to cast manifolds. How hard would it be to modify them, flipped backwards (swap to f4 flange, snake around abs and a/c on the passenger side) ? Love your single setup btw.. but I'm keeping my twins at all cost lol
Old 09-10-2010, 02:44 PM
  #71
bravoboost's Avatar
If anyones has pix.. plz post em up .. thanx
Old 11-07-2010, 10:57 PM
  #72
GMCBURBAN's Avatar
Awesome write up, Im starting mine next week!
  #73
GMCBURBAN's Avatar
Will try to keep an update to this thread going step by step..
Old 11-09-2010, 10:48 PM
  #74
KILLER-LS1's Avatar
Awesome man! what are your plans?
Old 11-10-2010, 06:25 PM
  #75
copley87blaze's Avatar
Great build Who tuned your car
Old 11-13-2010, 10:05 PM
  #76
KILLER-LS1's Avatar
Cunningham Motorsports in Murrietta, CA
Old 11-22-2010, 11:00 PM
  #77
StormesRacing's Avatar
Great Build!
What clutch are you running? and is anything done to the M6?
Old 11-23-2010, 11:00 PM
  #78
KILLER-LS1's Avatar
Originally Posted by StormesRacing
Great Build!
Its a clutchmasters stage 5, with a bone stock T56 (90k miles on it)
the clutch isnt strong enough but it does fine for the street. im going to switch to the new centerforce twin disc "DYAD" soon
Old 11-28-2010, 01:50 PM
  #79
Reject's Avatar
When i buklt my kit for the 76 i built it with stock manifolds facing backwards. Driver side pipe went under the engine/tranny to merge to the passenger side where the passenger side went next to the ac compressor to a t4 flange infront of the waterpump. The DP is routed around the alternator (everything is in the stock location ) and out to the rear via a stock y pipe location. Nothing went below the k member and nothing was lower than a stock y pipe exhaust. I built that in my backyard when i was 20ish, no garage. Now im building my new t6 setup truck manifold style.
The following users liked this post:
n2xlr8n66 (08-31-2021)
Old 12-14-2010, 02:57 AM
  #80
KILLER-LS1's Avatar
Update!! Just bought a precision 76gts, and am upgrading all the cold side piping and getting a new BOV as well. I also ordered a wolfe 6-point cage
new dyno number coming soon!
Quick Reply: How to DIY build a truck manifold turbo kit!
