GM Truck MP112 on Fbody LS1?
Old 07-21-2010, 03:16 PM
janaka's Avatar
Default GM Truck MP112 on Fbody LS1?
Ok as per my sig I do not have an Fbody but I have an LS1 from a TA installed in my Datsun. I have a guy sellilng a magnacharger from the Truck's (4.8/5.3/6L) and I'm interested to know if I can run this on my motor? Hood/cowl clearance isn't an issue for me in the swap and I'm only running an alternator and water pump from the TA, no PS/AC.
If someone could help clarify if this will work I would really appreciate it. FWIW the person selling it says it was on an LS2 vette
Thanks guys/gals.
Old 07-21-2010, 03:23 PM
LS1Tech Sponsor
hellbents10's Avatar
Well if it was a truck kit it was never on a LS2 Vette. The truck kit has a taller lower manifold and longer snout for the truck accessories.
the truck kit sits higher then the truck intake manifold to give you an idea of what you will be looking at.
For example my S10 here had a stock truck intake under the stock hood with the 5.3l in it, and here you can see I had to do a little cutting for the Maggie.
Quick Reply: GM Truck MP112 on Fbody LS1?
