Is a support required for twin turbo setup?
I'm in the middle of a conversion and twin turbo build. Is it really necessary to add a support for the turbo?
I am building custom up and forward headers similar to those built by Nelson Racing where the turbos are mounted even with the front of the motor. Do they need a support or will the headers be enough to support them?
Thanks!
Thanks!
In that case what does everyone use for supports? I have looked at a number of pics and none really show the support. Should it be attached to the clock or the frame? I'm running solid motor mounts.
