P1SC owners
Old Jun 2, 2010 | 12:12 PM
MR2liter's Avatar
Default P1SC owners
How much power are you making and what is your setup?
Old Jun 2, 2010 | 12:34 PM
pdasterly's Avatar
Nothing special. I made 470 rwhp, with 5.7 9.1cr. ls9 cam headers, no cats, stock ls1 intake, 3.5 pulley, 42lb injectors. My injectors are maxed out
Old Jun 2, 2010 | 01:55 PM
MR2liter's Avatar
Was that 6 psi?
Old Jun 2, 2010 | 04:36 PM
LSXFORMULA99's Avatar
i have tr224 cam with 112 lsa, long tube headers, ls6 intake, ported tb, tsp x pipe, 60lb injectors, in tank 255 pump, with 4.38 pulley making 5lb. 430hp 470trq on safe tune 11.1 a/f ratio. 8 rib setup....
Old Jun 2, 2010 | 04:39 PM
[QUOTE=pdasterly;13413747]Nothing special. I made 470 rwhp, with 5.7 9.1cr. ls9 cam headers, no cats, stock ls1 intake, 3.5 pulley, 42lb injectors. My injectors are maxed out[/QUOT
how much boost are you making with that pulley? i am trying to make around 10 and not sure what pulley i need. in the video your bypass valve sounds loud as hell. is that the one that comes with the kit?
Old Jun 2, 2010 | 04:58 PM
youngrigo's Avatar
Mods in sig....
Old Jun 2, 2010 | 04:59 PM
youngrigo's Avatar
[QUOTE=LSXFORMULA99;13414774]
Im on a 6rib and running the 3.0 pulley and making 9-9.5psi FWIW
Old Jun 2, 2010 | 05:19 PM
damn, i thought if i went with the 3.75 or 3.5 pulley i would get 10lb. but if u are on the 3.0 pulley only getting 9 idk what i should do. i guess every engine is different tho
Old Jun 2, 2010 | 06:39 PM
badass99ss's Avatar
Sold the car, but the build is in my sig. Could have got more hp if the fuel pressure would have held. It really needed a dual pump setup.
Troy
Old Jun 2, 2010 | 09:01 PM
JC70SS's Avatar
I am making 10-11 lbs with a MMS crank pulley and a 3.4 blower pulley. Other mods in sig.
Old Jun 3, 2010 | 12:08 PM
pdasterly's Avatar
I dont know what psi, my boost gauge isn't reading. The 470 was made with a 6 rib and 3.5 combo in the video in my sig. I upgraded injectors and purchased a morgan motorsports crank pulley which is bigger and replaced the procharger pulley with a 3.2, i picked both up here in the classified section. Also swapped stock ls1 intake for a professional products setup with throttle body, it was cheap. Looking for 600 rwhp. Bob from epp has a post saying his D1 went from 7 psi to 15 psi with the mms crank pulley swap. I'm waiting for a retune and new dyno number when I get my car back, will post video of dyno. As far as the bypass, I don't know. I bought the system used but the valve looks like the small ati valve. I have a k&n attached to the bypass valve, vented to the clouds.
Not my car but setup is the same
Old Jun 3, 2010 | 03:17 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Here's my brother's LT1 Formula from the old website. http://www.exoticperformanceplus.com...tCar.php?car=7 Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jun 3, 2010 | 03:29 PM
youngrigo's Avatar
Sounds about right - When i had the 3.4 pulley i made 468... This is thru a 9in
Old Jun 3, 2010 | 05:28 PM
pdasterly's Avatar
Compression ratio?
Old Jun 3, 2010 | 06:48 PM
sinful7's Avatar
what size pulleys come from ATI when you order the 6rib p1sc kit for a ls1 fbody? the 6psi kit version? im not at my car and wont be to measure my pulleys but thats the kit I ordered and I see 5.5psi roughly so its bout right, but as for measurements Im not sure.. Id like to go up to 10-12psi after the forged motor is built so what pulley size ill need then I have no idea haha!
Old Jun 3, 2010 | 06:55 PM
MR2liter's Avatar
Arrow
I'm pretty sure it comes with a 3.4 pulley from procharger. Anything smaller will cause belt slip , so an overdrive crank pulley is the answer. Why build the motor when you can just add meth and find a good tuner!
Old Jun 3, 2010 | 07:51 PM
i made 5psi with the 4.38 pulley, looking for 10 to 12 so im going to try the 3.6 pulley.
Old Jun 4, 2010 | 10:03 AM
Packy's Avatar
I am making 550rwhp and 515 ft lbs. thru the th-400. Cam is a true baby boost cam 214/224 .563/.563 114LSA and the converter is a PTC 3800. I make around 8-9 psi with a 3.5"RR pulley and MMS crank pulley. Alky control Kit with 50/50 mix. Moser 12 bolt with 3.73's but soon going to some 3.08's! My compression ratio is 9.6:1 on the motor. Other mods and info in sig.
Old Jun 4, 2010 | 11:16 AM
youngrigo's Avatar
Compression ratio?
Stock.... Thats on stock block, heads, cam
Old Jun 4, 2010 | 12:06 PM
Ericmck2000's Avatar
on a stock 4.8, with bigger injecters, and stock fuel pump, pushing up to 8 or so lbs before the fuel pump couldnt keep up...
Heres the dyno sheet.
http://truck.xtremeownage.com/images/dyno/SANY0029.JPG
