P1SC owners
Old Jul 29, 2010 | 11:14 PM
  #41
Garrett114's Avatar
With a p1 TR CHETR cam fast 78 Ported stock heads 9# I made 610RWHP 570RWTQ at 5800RPM after spark started blowing out. That was threw a RPM A4 and VIG stall
Old Jul 31, 2010 | 11:17 PM
  #42
B04W's Avatar
'03Z, 1-7/8" ARH, P1 and Alky Control
Old Aug 1, 2010 | 09:30 AM
  #43
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
My brother is the original owner of his '95 Formula. It has had a ProCharger P-1SC on it since sometime around '02-'03. It still has the stock cam, stock heads, engine hasn't been apart. He has run a best time to date of 10.914 @ 121.90 mph with a 1.452 sixty foot. It has a Moser 12 bolt with 4.30 gears, and he uses M/T ET Streets that are 28" tall. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Aug 1, 2010 | 10:38 AM
  #44
pdasterly's Avatar
nice, i wonder what number you will put up if you spin motor up to 6800 rpms.
Old Aug 2, 2010 | 10:20 PM
  #45
9t8z28's Avatar
stock ls1 bottom end and cam (6-speed)
p1sc w/ dual 3.5" I/C
LS6 intake
42# injectors
Racetronix pump
trick flow 215's
ati stock 6 rib 6" crank pulley/3.5" blower pulley
lth's and 2.5" duals out the back
7# of boost
486 rwhp
456 rwtq
Old Aug 3, 2010 | 07:34 AM
  #46
30th t/a's Avatar
LS6 intake
42# injectors
Racetronix pump
trick flow 215's
7# of boost
486 rwhp
456 rwtq
hmm...I would think with you having TFS 215s & a full exhaust that you would see more than 486/456. I hope to get 450-460 with 7-8psi with completly stock motor, but with a after market Y pipe & a SLP catback & Meth.
Old Aug 3, 2010 | 08:25 AM
  #47
LS1Tech Sponsor
With 8 psi of boost you can generally expect to see a 140 rwhp increase. With higher flowing heads, etc this number can go up. If you add 8 psi of boost to a stock LS3 engine that has headers and exhaust, you'll pick up more than 140 rwhp. Unlocked automatics with a higher stall may not show all this additional horsepower on a dyno, but the 1/4 time slips sure will. Bob
__________________
