can i get some opinions on this turbo please...
Im fabbing up my own rear mount turbo system on an other wise stock (except 255 pump and 42lb injectors/pmas blow through) 99 explorer 5.0 2wd. It will be intercooled and the hot side piping will be the stock stuff with no cats and wrapped. 10lbs is all i want. opinions please.
woops forgot the link:
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_795wt_1165
Because you said please, its up to you if you want to buy anything off ebay with someone that doesn't have 100% feedback, I prob wouldn't.
But as far as the turbo goes, the a/r seems a little small but Its probably ok since its a low boost setup on a 302ci engine and you could change it out later if they make a bigger a/r housing. I believe this was the same turbo model used in the base sts rearmount kits so it should be straight if its a legit garret.
Also those 42lb injectors are on the small side but should be good for your goal.
