Which 3 bar map for 102mm LsxR Intake?
looking to install map in front upper location provided by FAST.
port is drilled to 15/32's so it needs to be oring type map
3 bar map I have that will not work....12223861
please advise!!!
thanks in advance !
nobody here runs a fast 102 intake w/ a 3bar map? huh strange.....
please advise!!!
thanks in advance !
Dumb Ass Vette Moderator
If you are running a SD setup that needs a 3 bar sensor, you need to have a good solid piece of metal to screw in a 3 bar sensor sensor with threads. Either somewhere on the intake manifold or somewhere in the intake tubing after the TB.
I pride myself in professional clean work...... thanks for the suggestion but I refuse to put a barbed fitting w/vacuum hose to my map sensor, than what???? ziptie the map sensor to something? nahhhh...
lsxr102 intake has a port provided w/a bolt to hold map in place.
I cud call f.a.s.t and order one,
but prefer a GM# part....
anyone else have any info for a 3 bar map gm style that will fit?
will the duramax one work?
thanks in advance!!!
Restricted User
